BlueIris 1.1.16 and Deepquest/ Deepstack Question
Tue Nov 12, 2019 9:35 pm
mundmc offline
Re: BlueIris 1.1.16 and Deepquest/ Deepstack Question
First, that's amazing how quickly you were able to attend tho that, moreover fixing that.
Second, this is the first bug I have ever dicovered in my 7 years of Indigo use. Thank you for this opportunity :)
Follow-up question, but no pressure-
I originally had a trigger for:
1) Blue Iris detecting motion (you told me unnecessary, so I deactivated it)
-and-
2) Deepquest/state/stack (I am unsure what you want it called) detecting a Device State it searches for.
Deleting 1 and 2, it apepars DeepStack (my preference for names) continues to automagically detect objects for whom device states are present. This wasn/t initially intuitive for me, as I abviously assumed I had to do way mor labor than you Plugin naturally does for us (which is awesome, btw).
So, in the most appreciative way possible, I ask, "How do I tell it to stop :)."
Dude, lolol, I probably had a couple hundred megabytes of pictures of one of my daughter's plush dolls in her crib which the plugin correctly identified of my test of an Indigo DeepStack Device (Object:Other:Dog)! Literally, over a thousand of this damn dog :D
Tue Nov 12, 2019 9:42 pm
GlennNZ offline
Hi
Think I follow - gist being to many plush doll photos? Surely that is not possible really? :D
Think code currently save images if detected object found and device for this object exists (otherwise just calls triggers, but doesn't automatically save images)
So, if I'm following correctly, you could
1. delete device for object dont want object saved - won't save image for this object anywhere though
(triggers for it still should trigger)
or
2. I could add Camera selection to the device states and only save image if selected camera is there?
(would also need to check for multiple same object devices, but shouldn't be to much of issue)
Would that work?
G
Tue Nov 12, 2019 11:47 pm
GlennNZ offline
Ok, presuming I'm following issue correctly....
try
0.5.8
Adds Camera selection to each DeepState Object Device - each device will need to be reopened and Cameras selected.
Basically:
1. Will always trigger as needed, regardless of DeepState Device for object existing or not
BUT 0.5.8:
2. Will only save images for any DeepState Device object matching, as long as the Camera is selected within the DeepState Device selection
Such as here:
Thu Nov 14, 2019 4:59 pm
mundmc offline
Awesome, I will try it and report back!
Thu Dec 05, 2019 6:47 am
mundmc offline
I THINK this has sorted out the problem. Again, major kudos for integrating a locally run image classifier with Indigo- this is really amazing and more people need to see this!
Thu Dec 05, 2019 2:11 pm
GlennNZ offline
Cool.
I haven’t officially “released” it, or even written much of a post about it as yet.
Thought you could test!
Haven’t said that haven’t seen much need to change code for sometime. And will get on and look at the documentation... always the major drag....
Glenn
