BlueIris New Release 1.1.1.9 in Plugin Store
Version 1.1.5
In PluginStore.... soon....
New Functions for those running v5.
1. Add Action Group to Change BlueIris Macro Settings
These are the %1-%100 macros within BlueIris that you can overlay on any camera.
They go from 1-100, even though BI only shows first 10 in settings page.
This action setting allows the Plugin to change this Macro...
eg.
Temp Overlays, Location overlays, multiple possibilities
Select BlueIris Plugin Action to get this dialog
As you can see - supports Device and Variable Substitution
eg.
%%d:241092027:temperature%%
2. Add New Device Type (Optional) BlueIris User
- Add optional new device Blueiris user - updated with user information, including login details and time
- Add Trigger for particularly User Login: Unrelated to above device, can trigger when any BI Users login to the service
Need to add Blue Iris Server Alert for User Login:
From Within Blue Iris Server, Main Settings, Users, Choose particular User
Actions: On Login:
+ Web request or MQTT
Similar to Camera Alerts - just with username at end eg.
eg.
3. Add Parsing of BlueIris Logs
This enables Camera Motion alerting without setting up anything within BI Server, and User Login from Log alone.
Presently this adds little further, except easy setup, and is slower (seconds only) at alerting.
Future use though for Sentry alerts, for Camera based triggering....
Adds new Camera device setting 'TriggeredbyLog' true if log message has triggered motion sensing.
Potentially adds issue with User Login triggering twice if running user login alert, and Parse logs. To overcome create BlueIris User Device for that user which will fix.
More to come...
Glenn
eg.
eg.
Actions: On Login:
- Code: Select all
http://IndigoIP:4556/&CAM/&TYPE/&PROFILE/glenn
Post/payload: Indigo
eg.
More to come...
Glenn
