Thanks for the heads-up! Hopefully they'll update the UI, it's one of the few things I don't like about Blue Iris.
Terry
lanbrown wrote:Blue Iris has had three minor release updates since it was released on May 31st. So far, those releases haven't restored full functionality from the plugin.
lanbrown wrote:If you don't want to mess your instance up, just let me know what you need off of mine.
lanbrown wrote:When you install v5, v4 is still there. One of the steps is pointing the web server to the correct folder; it lists the old v4 location. So in theory, you should be able to not use the service and just open the executable to run the program. Then all you might need to do is update the web server path but it could also be that the two installs technically have separate configs.
lanbrown wrote:I upgraded to 5.0.50 the day it was released and it did not resolve the issue in getting the status of the Blue Iris server.
I assume the the new pre-release plugin is compatible with the changes Ken made?
You could also just change the plugin version to v5 to match that of Blue Iris and just have this plugin work with Blue Iris 5 only. The plugin has been stable. If you want the latest features the Blue Iris offers in the plugin, they would need to upgrade to v5 anyway. You might want to put a check in the plugin when it talks to the Blue Iris server to make sure the correct plugin is being used. If not, you could provide a URL to download the correct one. An example, they download the v5 plugin and they are running Blue Iris 4. If the plugin version is 5 and Blue Iris is 4, output in the log the URL to download the v4 plugin.
autolog wrote:Hi Glenn,
I have installed the new plugin (version 1.0.3).
I am running Blue iris (Version 5.0.0.52 x64).
Since I disabled the plugin (when I installed BI5), I have installed two Reolink RLC-423 cameras and a Foscam R4 camera.
When I start the new plugin, these cameras aren't listed.
Should they be listed or am I meant to use New... to add a camera - if so, I can't find how to select the new ones.
The Indigo Blue Iris Server Device seems to work OK and an existing Foscam camera is showing up as an Indigo device and showing when motion is detecte d(this camera was previously defined when the plugin was working with BI4).
Thanks for creating this plugin.
PEBCAK: Solution was to RTFM!!! - Thanks for the reminders/pointers.![]()
All working now.
