BlueIris version 4.8.4.0 Causing some cosmetic errors
Hi all,
Just a heads up that latest version of BI causes an occasional Plugin debug error - with a caught exception.
After some trouble shooting it appears there is a BI server error, with some changes it no longer returns correct Json code, so the plugin has an exception at this point.
(missing a comma on the returned json)
Hard to spot - but online json validators great! here:
I have emailed Ken BI developer and I am sure he will update/fix soon.
It does seem only cosmetic when camconfig actions are run - the action is completed successful, just error on completion.
So probably would still upgrade, but YMMV
Edit: BI developer on to it and should be fixed in next version today ... (if known he would be that quick wouldn’t have posted this!)
Cheers
Glenn
- Code: Select all
"result":"success","session":"2f320b5d7f0e2e9c7333400660cd00584","data":{"profile":1,"lock":0"pause":0,"push":false,"audio":true,"motion":true,"schedule":false,"ptzcycle":false,"ptzevents":false,"alerts":0,"output":false,"setmotion":{"audio_trigger":true,"audio_sense":10000,"usemask":false,"sense":9550,"contrast":21,"showmotion":0,"shadows":false,"luminance":false,"objects":false,"maketime":10,"breaktime":100},"record":2}}
- Code: Select all
lock":0"pause":0
Cheers
Glenn
