BlueIris version 4.8.4.0 Causing some cosmetic errors
Thu Nov 15, 2018 5:17 pm
GlennNZ offline
Hi all,
Just a heads up that latest version of BI causes an occasional Plugin debug error - with a caught exception.
After some trouble shooting it appears there is a BI server error, with some changes it no longer returns correct Json code, so the plugin has an exception at this point.
(missing a comma on the returned json)
"result":"success","session":"2f320b5d7f0e2e9c7333400660cd00584","data":{"profile":1,"lock":0"pause":0,"push":false,"audio":true,"motion":true,"schedule":false,"ptzcycle":false,"ptzevents":false,"alerts":0,"output":false,"setmotion":{"audio_trigger":true,"audio_sense":10000,"usemask":false,"sense":9550,"contrast":21,"showmotion":0,"shadows":false,"luminance":false,"objects":false,"maketime":10,"breaktime":100},"record":2}}
Hard to spot - but online json validators great! here:
lock":0"pause":0
I have emailed Ken BI developer and I am sure he will update/fix soon.
It does seem only cosmetic when camconfig actions are run - the action is completed successful, just error on completion.
So probably would still upgrade, but YMMV
Edit: BI developer on to it and should be fixed in next version today ... (if known he would be that quick wouldn’t have posted this!)
Cheers
Glenn
Sun Nov 18, 2018 8:21 pm
srkinard offline
Re: BlueIris version 4.8.4.0 Causing some cosmetic errors
Saw this error in my logs today...thanks for the info. I was wondering if the latest BI update had done it since I've made no changes to the Indigo system in weeks.
Ross
Mon Nov 19, 2018 1:59 am
GlennNZ offline
Ross
Very much the same for me.
Took a bit of locating to find the issue as haven’t looked at code in a while.
Ken the developer of BI was pretty quick and already fixed in 4.8.4.1!
Mon Nov 19, 2018 11:49 pm
srkinard offline
I've gotten support a few times from BI and Ken was always really responsive and helpful. One of his team, Jennifer, helped me sort out license issues when I moved the installation to a different server when the first had a failure that rendered me unable to deactivate it. They've been really good with customer service for the 3+ years I've used BI.
