Seeker wrote:i just had some time to play with this again. i upgraded from an early version to version 8. none of the communication seems to be working (profile update, triggers). did i miss another necessary step for the upgrade?
GlennNZ wrote:Seeker wrote:i just had some time to play with this again. i upgraded from an early version to version 8. none of the communication seems to be working (profile update, triggers). did i miss another necessary step for the upgrade?
Yes
Everything has changed !
The instructions are all updated - but need to change the trigger in BlueIris webalerts to be compatible to the new version
GlennNZ wrote:The port number is now the plugins port, not Indigo web servers
The plugin creates its own server
Don’t use 8176 - Indigo ones
Plugin default is port 4556
Some exchange 8176 for 4556
IndigoIP:IndigoPort/static/CameraName-cliplist.html
eg
192.168.1.6:8176/static/FrontLow-cliplist.html
neilk wrote:Hi Glenn,
I cannot believe how much progress and so responsive you have been on this, it really is a fantastic work including your documentation, so once again thanks. One thing I am noticing is that my Blue Iris Server Device stops updating. If I reload it refreshes, but for example it hasn't updated since 15:23 yesterday. I don't yet have a need for it as I have BI Tools with notifications setup "pre-plugin" so no issue for me but I thought I should let you know. It may be one of those difficult issues as I have followed through almost all of your versions and tinkered before that. No log errors or warnings and triggers, gif creation etc are all working fine.
Neil
24 Feb 2018, 12:00:09
Trigger Blue Iris Front Door Motion <<Triggers OK
24 Feb 2018, 12:02:55
BlueIris Plugin Stopping device: BlueIris Camera Living_Room <<<<<Stop Living_Camera via an update to image size
24 Feb 2018, 12:03:11
Trigger Blue Iris Front Door Motion <<< Front_Door still triggers OK
24 Feb 2018, 12:04:30
24 Feb 2018, 12:07:41
24 Feb 2018, 12:07:58
BlueIris Plugin Stopping device: BlueIris Camera Front_Door <<<< Now I have changed image data and saved, Front_Door Cam stops and I try and trigger but nothing happens
24 Feb 2018, 12:09:52
Reloading plugin "BlueIris Plugin 0.8.0"
Stopping plugin "BlueIris Plugin 0.8.0" (pid 50200)
BlueIris Plugin Restarting/or error. Stopping thread.
BlueIris Plugin Stopping device: Blue Iris Server Device
Stopped plugin "BlueIris Plugin 0.8.0"
Starting plugin "BlueIris Plugin 0.8.0" (pid 54253)
BlueIris Plugin
BlueIris Plugin ================================================ Initializing New Plugin Session =================================================
BlueIris Plugin Plugin name: BlueIris Plugin
BlueIris Plugin Plugin version: 0.8.0
BlueIris Plugin Plugin ID: com.GlennNZ.indigoplugin.BlueIris
BlueIris Plugin Indigo version: 7.1.1
BlueIris Plugin Python version: 2.7.10 (default, Feb 7 2017, 00:08:15) [GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
BlueIris Plugin Install Path : /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/BlueIris.indigoPlugin/Contents/Server Plugin
BlueIris Plugin Path to Gifsicle : /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/BlueIris.indigoPlugin/Contents/Server Plugin/gifsicle/1.91/bin/giflossy
BlueIris Plugin ==================================================================================================================================
Started plugin "BlueIris Plugin 0.8.0"
BlueIris Plugin Http Server Listening on TCP port 4556
BlueIris Plugin BlueIris Update: Update Checking. Your Current version is: 0.8.0
BlueIris Plugin BlueIris: Update Checking. The Github Latest release is: 0.8.5
BlueIris Plugin BlueIris: Update Checking. Please visit the Plugin Store to Download
BlueIris Plugin BlueIris Plugin: Update Checking. Update is Available. Taking you to plugin Store.
24 Feb 2018, 12:11:36
Trigger Blue Iris Front Door Motion <<<<<<< After reboot it triggers when I try again
neilk wrote:It could well be that it is to do with lost communication to BI and then not recovering, I was on 8.0 and now upgraded to 8.5 and I may have a something funky going on with my network that I am trying to pin down but it could have also been the connection where I was yesterday.
Neil
CliveS wrote:It maybe related to Neil's locking up but if I change a camera setting it closes the camera but does not restart it until I restart.
GlennNZ wrote:CliveS wrote:It maybe related to Neil's locking up but if I change a camera setting it closes the camera but does not restart it until I restart.
Clive - thanks for the log.
Checking now and just seems comestic - Device Stop is logged at different level to Device Start. But both are happening (turn on debug logging and you'll see)
Triggers:
Fount it - squishing bug now.
After editing device or device restart defaults to disabled until checked with BIServer that Camera is online. (occurs every minute or so)
Changing behaviour to after startup/or editing defaults to Online as that probably makes sense
G
Thinking about your issue. I think it will be because you have two BISever devices (probably one hiding somewhere in main directory)
Have a look and I’ll add a startup check for same.
If it happens again - turn on debug logging and check first box - BI Server Session only. Let this run for 10 minutes or so and PM me, or pastebin.org the resulting output - from the Event Logs directory.
Should be something fairly obviously within this log I would guess.
