Accessing Sensibo reported temp & humidity
Fri Feb 15, 2019 11:27 am
dherren offline
I have this plugin happily controlling my Mitsubishi heat pump. In the iPhone app and in Indigo, the plugin displays the current temperature and humidity (as well as other data in the Custom States fields).
I have found no way to access this data. What I would like to do is to only turn on the heat pump if the temperature is below a particular threshold. Is there some way to set a variable based upon the Custom States data?
