Sensibo Plugin
Wed Jun 01, 2022 7:02 pm
Re: Sensibo Plugin
Let me have a look now I’ve got an API key.
If you want to send me your key as well if you’ve got different models/devices, that will help even more.
Thu Jun 02, 2022 10:37 am
Re: Sensibo Plugin
Hi
For anyone watching/interested, please try v2.0.0 and let me know how it goes.
As far as I can tell, it addresses all the queries asked on this thread:
  • Reason = 404 Client Error: Not Found for url
  • Reason = list index out of range
  • Reason = 'temperature'
  • Sensibo always defaults to 20 degrees celsius when setting a target temp
  • EOF occurred in violation of protocol (NOTE: This is due to your version of MacOS - you need to upgrade to High Sierra or beyond)
This is still written in Python2 to address the old issues before I upgrade it to Python3. I've only tidied and fixed code so it should be compatible with your current installs and upgrade in-place.
Python 3 version will split devices by type (Purifier, AC, Motion Sensor, etc) and will need you to reconfigure some of your actions/control pages etc.
Peter
Thu Jun 02, 2022 6:00 pm
new2me07 offline
Re: Sensibo Plugin
Thanks Peter!
Fri Jun 03, 2022 4:42 pm
Digiacomo offline
Re: Sensibo Plugin
I tried v2.0.0 and it did eliminate the temperature related error. Now all my log entries are green. The log shows that it successfully loaded the list with all my devices, however, it only offers the purifiers (not the AC controllers) as available options for new devices. And it also does not seem to offer the ability to change a state (e.g. fan speed), only to read current state. Not sure if that's by design or if something isn't working for me. Is this the same behavior other people are seeing?
Sat Jun 04, 2022 11:40 pm
Re: Sensibo Plugin
Hi
Are you able to send me your API key via pm so I can experiment with what data you’re seeing; I’ve been playing with the code for a few more days so I can get a lot better out of it, but I still only have one persons data to code against.
Green means you’ve got debug turned on - I think I might have set it on by default during testing; go to plugin config to turn it off.
I’ve not touched the actions (yet) - they’re doing/not doing whatever they were in the authors old code.
Peter
Mon Jun 20, 2022 4:45 pm
new2me07 offline
Re: Sensibo Plugin
Any Updates?... It would actually be kind of useful to automate the air purifiers as well. The weather has been amazing the last couple of days so the windows have been open and everything is great until I hear all the purifier start to spin up :(
Mon Jun 20, 2022 5:14 pm
Re: Sensibo Plugin
I can’t remember whether I made changes after uploading that version; I was hoping Digi would send me his key but I’ve had nothing.
Sun Jul 03, 2022 9:20 pm
new2me07 offline
Re: Sensibo Plugin
All I seem to get is
Sensibo Error Error Error: Reason = list index out of range
IDK what could have changed over the passed couple of days and now but I don't think it likes it.
Did all the basics, restart Mac, restart indigo, reload plugin... nothing helps
Thu Jul 14, 2022 9:44 am
new2me07 offline
Re: Sensibo Plugin
Anything I can do to further the development effort? I generally can't write anything from scratch but can usually accomplish small tasks involving code or troubleshooting.
Wed Aug 03, 2022 1:26 pm
Re: Sensibo Plugin
I'm looking at this tonight.
I didn't realise you'd sent me your API key.
Peter
Wed Aug 03, 2022 2:34 pm
Re: Sensibo Plugin
Try v201 here.
Note that this is what's been running on my mac for a month, but i'm currently on holiday and my Mac has decided to reboot into an OS upgrade so although I can get in to the fileshares, I can't currently get into the UI / Indigo to check it.
I think by the morning I should have access back to my Mac again.
Peter
Wed Aug 10, 2022 1:13 pm
Re: Sensibo Plugin
See viewforum.php?f=378 for any published updates to this plugin, both py2 and py3.
Mon Nov 28, 2022 12:20 pm
dherren offline
Re: Sensibo Plugin
any chance that this will ever work again?
Thu Jul 13, 2023 7:36 pm
mclass offline
Re: Sensibo Plugin
The referenced topic has been locked, with the last post almost a year ago. Is there any plans for a Python 3 version any time soon? The next version of Indigo will render the current plugin unworkanble :(
mclass
Fri Jul 14, 2023 11:35 am
Re: Sensibo Plugin
I’m aware of the (unpublished) deadlines for Python 3 in terms of indigo releases and there will be a plugin out by that time.
Peter
