Sensibo Plugin
Mon Jan 29, 2018 12:29 am
deuan offline
Sensibo Plugin
A new Sensibo Plugin has been released into the store.
This plugin will allow you to control your Sensibo enabled AC controllers. Hope you all enjoy.
After you have downloaded and installed from the indigo store, click Plugins and select Sensibo/Configure
If you do not already have your Sensibo API key, you will need to login to Sensibo and create an API key here https://home.sensibo.com/
Copy your API Key and paste it in the Sensibo API Key box within the configuration screen.
Click Save
Now simply add a new device for each Sensibo Controller you have.
That's it.
* 30/01/2018 V0.1.5
    Bug fix for shutdown process
* 31/01/2018 V0.1.29
    Added Control for setting AC Fan Levels
Mon Jan 29, 2018 7:35 am
chinasso offline
Re: Sensibo Plugin
Great!! I test it. Thanks!!
Enviado desde mi iPhone utilizando Tapatalk Pro
Wed May 23, 2018 3:27 pm
billorav offline
Re: Sensibo Plugin
Is there a way to show Fahrenheit in indigo instead of Celsius? The remote Snesibo application lets you change to either mode.
Bill
Wed May 23, 2018 3:29 pm
Re: Sensibo Plugin
One option is the Scale Adapters Plugin.
Wed May 23, 2018 9:06 pm
billorav offline
Re: Sensibo Plugin
I just bought Sensibo on Amazon and had the understanding that we can change temps on the IR controlled split HVAC units by one degree. In Celsius 19c = 66.2f. and 20c = 68f. Although this doesn't sound like much we have become accustom to be able to change the thermostat by 1 degree F. If we use the Celsius method (without 3 digits) our changes could result in a 2 degree swing. We are converting a zoned master HVAC unit to a split unit and our current HVAC controls are quite precise in Indigo (to one degree Fahrenheit see below). Any suggestions on how to get more than 2 digit accuracy in Celsius out of the Sensibo plugin would be vey helpful.
Wed May 23, 2018 9:20 pm
Re: Sensibo Plugin
Sorry, ignore my post above about the Scale Adapters Plugin. It's a great plugin, but clearly not what you need.
Wed May 23, 2018 9:45 pm
billorav offline
Re: Sensibo Plugin
It does do the C to F conversion out, but I haven't found a way to convert temp in back to Sensibo. May be missing something.
Thanks.
Mon Aug 20, 2018 11:12 am
Grevling offline
Re: Sensibo Plugin
I can't get this to work. Have followed all steps above, bug keep getting this error message:
Sensibo Error Error Error contacting Sensibo. Reason = 404 Client Error: Not Found for url: https://home.sensibo.com/api/v2/pods//m ... cxfC7FiQqq
Any ideas?
G
Mon Sep 24, 2018 2:00 am
Grevling offline
Re: Sensibo Plugin
Ok, so now I got it to register the API Key, and the plugin is "online" with Sensibo.
I have created a device, but the only state I can get out of it is "True" and "False".
How do I get control over my Sensibo trough the device, e.g. change temperatur, fans speed etc.
My other heating devices (a couple of z-wave thermostats) have controls for changing these values, but the device I created for Sensibo plugin does not.
I'm still pretty green with Indigo, so I'm trying to learn this. Any pointers are very welcome :roll: :roll: .
G
Thu Feb 14, 2019 12:55 pm
dherren offline
Works fine. Feature request?
This plug-in is working fine to control my Mitsubishi heat pump. I can see temperature and humidity reported in indigo but I see no way to use that in any meaningful way. For example, I would like to turn on the heat pump at a certain time each day, but only if the heat is below a particular temperature. Could the plug-in be modified to set variables?
