New Release 0.10.02 iRoomba Plugin
Sat Feb 24, 2024 12:56 am
GlennNZ offline
Hi all,
New version down below that restores cloud mapping data, and add favorites mapping data download from cloud AWS.
Other libraries haven't figured this out yet, but a bit of reverse proxy/man-in-middle enabled discovery of changes to cloud location.
Updated , also found favorites data - and have added this as a separate action group!
Favorites is far more useful in my mind, and at each request re-check the favourite based on ID. Essentially meaning you can update the favourite on the irobot app, and this new update will be applied when run. Although will need to update the mapping/favourites data with device edit button/cloud connect so that locally reflects these changes.
Underlying aspect here is we never download new cloud info without user intervention.
https://github.com/Ghawken/Indigo-iRobotRoomba/releases
Version 0.10.02
Indigo API 3.4 Only
Fix AWS Server authorization for access to mapping data once again. Redo end-points.
Download and parse Favorites per Robot via cloud connection, saving to file for future use.
(.10.0.02 - update, loads file after creation so immediately available for use)
eg. Same as Room data - can download once and then disable internet if preference.
Add Action Group for 'Favourites'. Enables to select a Favourite set of rooms, cleaning aspects for each iRoomba
Add refill Tank messaging (missing)
With Latest iRobot App / Android APK App as source - update all messaging relating to error and not ready states.
Update Logging to Log and File as seperate instances. (my usual log approach)
Fix for Json notification messaging load error. (created by updates to 10.01.01)
Update logging - try to clearly state that device connected without to much messaging.
0.9.37
Indigo 2023.2+ API 3.4+ only
Fix paho-mqtt to early version to avoid incompatibly
New Release versioning for store
