pmgendon wrote:it appears that the problem was caused when the roomba changed IP. I assigned a fixed IP to the unit and so far, so good!
keep up the good work,
Good to hear.
Does restart once every 24 hours as found occasional connection to Roomba failed and was only way to reset it completely.
Also I uncommonly get a regularly run of connection failure messages - if fails three times will restart to reset connection. This typically is caused by when the Roomba is dead somewhere and runs out of battery. Also should look at making this a bit more obvious
Glenn
