vtmikel wrote:Sorry to report .5 broke my connection. Log had numerous timeout attempts. I reverted to the last version from last night and it worked again. Will post my log from the .5 upgrade shortly.
Ok
You might be special case!
Need to re-generate password or at least try to get software version to make decisions. (couldn’t see another way around this - and your version will be ‘unknown’ as haven’t generated password). Thought better default to the non-s9 setting which is probably why had troubles
Basically - do the get password bit,
Press the button - even if don’t press the iroomba button - shouldn’t matter.
Just try, probably save and/or then restart plugin
Think will fix
(Obviously others will have to generate password to get any further and shouldn’t see this issue)
If wrong please let me know and certainly meanwhile the new device force SSL TLS setting within each iRoomba device should overcome if still issues/if automatic not working
Glenn
Should say good luck with S9 - looks very good - tempted to buy it if was available here!
