Re: Only one node neighbors node1 ?
Posted: Sun Jul 08, 2018 8:03 am
- Code: Select all
Script 056 - Relay Switch [822568]: 12, 27, 28, 39, 50, 54, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
Script 056 - Relay Switch 2 [2804526]: None
Script 057 - Relay Switch [386978470]: 3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
Script 058 - Relay Switch 2 [18186564]: None
Script 059 - Relay Switch 2 [1985889449]: None
Script 061 - Relay Switch 2 [1443673078]: None
Script 062 - Switch 2 [1056355098]: None
Script 074 - Relay Switch 2 [1407270308]: None
Script 1. OG Temperatur [301794450]: None
Script 1. OG Tilt/Tamper [699741549]: None
Script 107 - Relay Power Switch [24154744]: 9, 12, 54, 58, 62, 63, 86, 97, 100
Script 114 - Relay Power Switch [742161752]: 3, 4, 9, 12, 27, 39, 50, 54, 56, 57, 58, 59, 62, 63, 74, 78, 80, 86, 97, 100, 113
Script 122 - Switch 2 [513441554]: None
Script 131 - Switch 2 [1141000126]: None
Script 133 - Wall Plug Relay (FGWP102) [1711124218]: 3, 4, 10, 12, 27, 58, 59, 60, 74, 78, 80, 122
Script 2. OG Temperatur [1843310254]:
Script 2. OG Tilt/Tamper [1177008313]:
Script Arbeitsplatte [139991636]: 3, 4, 10, 27, 54, 56, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
Script Arbeitsplatte links [117201011]: 3, 4, 10, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 103, 131, 133
Script Außenlampe Eingang [924668941]: 3, 4, 12, 27, 28, 57, 58, 59, 60, 61, 62, 74, 78, 86, 97, 103, 122
Script Bewegungsmelder 1.OG [348473248]: 1, 3, 27, 28, 39, 50, 54, 56, 57, 58, 59, 62, 78, 122, 131
Script Bewegungsmelder 2. OG [381893400]: 1, 3, 4, 9, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97
Script Bewegungsmelder Gästeklo [68361281]: 1, 3, 9, 12, 58, 59, 60, 62, 74, 78, 80, 97, 100, 122
Script Bewegungsmelder Küche [89688834]: 1, 3, 4, 9, 12, 22, 27, 39, 56, 58, 60, 61, 62, 63, 75, 78
Script Boxenlampen [1875461131]: 10, 12, 27, 57, 58, 60, 62, 74, 78, 86, 122, 133
Script Dachfenster links [1440251296]: 27, 28, 39, 50, 54, 56, 57, 59, 62, 76, 86, 97, 122
Script Dachfenster links Tamper Switch [73192680]: None
Script Dachfenster links Temperatur [1489754979]: None
Script Dachfenster rechts [1618377781]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 97, 124
Script Dachfenster rechts Tamper Switch [163594255]: None
Script Dachfenster rechts Temperatur [1957884309]: None
Script Deckenlampe [1433310462]: 3, 4, 12, 56, 58, 59, 60, 62, 74, 78, 80, 122, 133
Script Deckenlampe Dimmer [140509571]: 3, 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 80, 97, 122, 131, 133
Script Deckenlampe Küche [1716683166]: 3, 4, 10, 12, 27, 28, 54, 57, 58, 59, 60, 61, 74, 78, 80, 86, 97, 103, 122, 131, 133
Script Deckenlampe Ruth [1896970978]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 62, 76, 86, 97, 122, 131, 133
Script Deckenlampe Studio [1685088213]:
Script Eingangstür [1061866982]: 3, 4, 12, 27, 54, 57, 58, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131
Script Eingangstür - Tamper Switch [1976961658]: None
Script Eingangstür - Temperatur [74210471]: None
Script Esstisch [1436322377]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 59, 60, 61, 62, 74, 78, 80, 86, 97, 103, 122, 131, 133
Script Fenster Ruth [1554611290]: 1, 3, 27, 28, 39, 54, 57, 58, 59, 74, 76, 86, 97
Script Fenster Ruth Tamper Switch [627069345]: None
Script Fenster Ruth Temperatur [584178040]: None
Script Fenster Studio [615947154]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 124
Script Fenster Studio Tamper Switch [1086255929]: None
Script Fenster Studio Temperatur [1895929939]:
Script Fenster W. li. [67242493]: 1, 9, 27, 39, 54, 57, 58, 59, 62, 86, 97
Script Fenster W. li. Tamper Switch [132345432]: None
Script Fenster W. li. Temperatur [1873863007]: None
Script Fenster W. re. [662606495]: 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 76, 86, 97, 114, 122, 131
Script Fenster W. re. Tamper Switch [1409009467]: None
Script Fenster W. re. Temperature [1990184362]: None
Script Helligkeit 1.OG [1836194591]: None
Script Helligkeit 2.OG [207926896]: None
Script Helligkeit Küche [978386071]: None
Script Keller Nord Tamper Switch [1447841539]: None
Script Keller Nord Temperatur [1762776311]: None
Script Keller Süd Tamper Switch [1556105200]: None
Script Keller Süd Temperatur [703541392]: None
Script Kellerfenster Nord [1227213437]: 1, 58, 60, 62, 122, 131
Script Kellerfenster Süd [808008304]: 1, 3, 58, 60, 61, 62, 63, 74, 78, 80
Script Keyfob (FGKF601) [374652588]: 1, 3, 4, 9, 10, 12, 27, 28, 50, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 100, 122, 124
Script Klofenster [1234445639]: 3, 4, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 78, 80, 86, 97, 122, 131
Script Klofenster - Tamper Switch [35483318]: None
Script Klofenster - Temperatur [135929692]:
Script Küche Temperatur [1094029124]: None
Script Küche Tilt/Tamper [99430321]: None
Script Küchenfenster [1725081489]: 1, 4, 10, 12, 27, 56, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 124, 131
Script Küchenfenster - Tamper Switch [829195639]: None
Script Küchenfenster Temperatur [9646215]: None
Script Luminance Gästeklo [1285976121]: None
Script Rauchmelder [887932831]: None
Script Rolladen Dach links [1646658939]: 27, 28, 39, 54, 56, 57, 58, 59, 60, 76, 86, 97
Script Rolladen Dach rechts [1423365922]: 3, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
Script Schrankbeleuchtung [1122371918]: 27, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 86, 97, 122, 131
Script Schreibtischlampe [15714752]: 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 86, 122, 131
Script Sirene [92722386]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
Script Sirene Tamper Switch [136256874]: None
Script Sirene Temperature [7613047]:
Script Stehlampe [832091583]: 4, 10, 27, 28, 54, 57, 58, 59, 61, 62, 74, 76, 78, 80, 86, 122, 131, 133
Script Stehlampe Ruth [13889882]: 3, 4, 12, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 86, 97, 122, 131, 133
Script Stehlampe Schlafzimmer [1640544170]: 3, 12, 27, 28, 39, 50, 56, 57, 58, 59, 62, 74, 76, 78, 80, 86, 97, 122, 131
Script Telefonlampe [1459060434]: 3, 10, 12, 27, 56, 58, 59, 61, 62, 74, 76, 78, 86, 97, 122, 131, 133
Script Temperatur [114756656]:
Script Temperature Gästeklo [856118609]: None
Script Terrassentür [1967020541]: 3, 4, 10, 12, 27, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
Script Terrassentür - Tamper Switch [1983697695]: None
Script Terrassentür Temperatur [1746329838]: None
Script Tilt/Tamper [1216827691]:
Script Tilt/Tamper Gästeklo [682227201]: None
Script Tischlampe [1880470196]: 4, 27, 28, 39, 50, 54, 56, 57, 59, 70, 74, 82, 84, 86, 94, 97, 100, 102, 104, 124, 126, 127
Script Treppenhaus EG [1417133177]: 4, 12, 27, 28, 39, 56, 58, 60, 62, 74, 80, 86, 97, 103, 122, 131
Script Treppenhaus OG [190514559]: 3, 10, 12, 27, 28, 39, 50, 56, 57, 58, 61, 62, 74, 76, 78, 80, 86, 97, 103, 122, 131, 133
Script Ventilator [1038077280]: 1, 3, 4, 10, 12, 27, 28, 54, 56, 57, 58, 59, 60, 62, 70, 73, 76, 77, 78, 80, 82, 85, 86, 97, 99, 102, 122, 124, 126, 127, 130
Script Wassersensor [1307154806]: 12, 58, 60, 61, 62, 131
Script Weihnachtsbaum alt [176679712]: 1, 114
Script Zwischenstecker [1489676697]: 3, 4, 10, 12, 27, 54, 57, 58, 60, 62, 74, 80, 97, 122, 131, 133
