Z-Wave Node Matrix Plugin Updates
Tue May 01, 2018 6:13 am
Updates to the Z-Wave Node Matrix Plugin will be posted to this thread.
Tue Jul 17, 2018 6:41 pm
Re: Z-Wave Node Matrix Plugin Updates
The Z-Wave Node Matrix Plugin v0.3.01 is now available.
v0.3.01
  • Fixes bug in listing of nodes for combination devices (multiple devices that use the same address).
  • Fixes bug where font setting only affected the chart's title.
  • Refactors code to establish device plotting properties.
  • Increments Indigo Server API requirement to 2.0
v0.2.9
  • Refactors plugin method names to PEP 8.
v0.2.8
  • Fixes bug in naming of PluginConfig.xml (which caused problems on systems set up as case sensitive.
v0.2.7
  • Updates plugin update checker to use curl to overcome outdated security of Apple's Python install.
The plugin can be downloaded here.
The plugin documentation can be viewed here.
Wed Aug 22, 2018 7:18 pm
Z-Wave Node Matrix Plugin v1.0.01 is now available.
  • Takes plugin out of beta.
  • Fixes bug where change in debug level required a plugin restart to take effect.
  • Code refinements.
Thu Apr 04, 2019 1:38 pm
Z-Wave Node Matrix Plugin v1.0.07 is now available.
  • Ensures that the plugin is compatible with the Indigo server version.
  • Standardizes Support URL behavior across all plugin functions.
  • Updates default image save location to current install path.
  • Removes plugin update checker.
Sat Nov 09, 2019 6:10 pm
Z-Wave Node Matrix Plugin v1.0.09 is now available.
  • Fixes bug for horizontal line marker style.
Tue Nov 10, 2020 3:26 pm
Z-Wave Node Matrix Plugin v1.0.15 is now available.
v1.0.15
  • Fixes broken link to readme logo.
  • Fixes broken symlinks.
v1.0.14
  • Better integration of DLFramework.
v1.0.13
  • Code refinements.
v1.0.12
  • Removes all references to legacy version checking.
v1.0.11
  • Fixes bug where plugin would error out when no Z-Wave devices present.
v1.0.10
  • Adds asterisk to plugin configuration dialog dropdown menus to indicate default setting.
Thu Mar 31, 2022 3:31 pm
Z-Wave Node Matrix Plugin v1.0.16 is now available.
Includes a fix for the transition to Indigo 2022.1 and Python 3. Users that expect to upgrade to Indigo 2022.1 should apply this update.
This release is only appropriate for Indigo 2021.2 and earlier.
Tue May 10, 2022 5:56 pm
Z-Wave Node Matrix Plugin v2022.0.2 is now available.
Updates plugin for Indigo 2022.1 and Python 3. Note that this version of the plugin requires at least version 2022.1 of Indigo. It will not work on older versions. Also, the plugin documentation referenced below may not yet be updated to reflect all the changes in this release (the docs will be updated soon.)
  • Fixes bug where chart height and width settings were reversed.
  • Improves dummy device data (for testing).
  • Adds tight_layout (reduces empty space around chart).
  • Adds new marker styles.
  • Standardizes Indigo method implementation.
Do not use plugin version 2022.0.1 as it may obscure your device data with dummy testing data.
The plugin documentation can be viewed at the Wiki.
Sat Jul 30, 2022 5:03 am
Z-Wave Node Matrix Plugin v2022.0.4 is now available.
v2022.0.4
  • Adds foundation for API 3.1.
  • Fixes bug where plugin searches for Z-wave devices.
v2022.0.3
  • Moves plugin environment logging to plugin menu item (log only on request).
Wed Feb 14, 2024 2:04 pm
Z-Wave Node Matrix Plugin v2023.1.0 is now available.
Enhancements
  • Adds new marker style X (filled).
  • Adds "About Matplotlib" to plugin menu.
Bug Fix
  • Fixes bug where charts wouldn't generate in Matplotlib 3.8 (shipping with Indigo 2023.2). Prior versions of the plugin should still work for prior versions of Matplotlib.
As usual:
  • Code refinements.
Sun Mar 03, 2024 10:20 am
Z-Wave Node Matrix Plugin v2023.1.1 is now available.
  • Minor UI and Wiki enhancements. This is a cosmetic update --it's safe to skip it if you're on v2023.1.0.
