Automatic OBD-II Indigo Plugin
Fri Aug 31, 2018 4:05 am
How much power does it consume.
Ie when I do not run the engine for 2 weeks will it drain the battery ... will the car still start?
Fri Aug 31, 2018 5:47 am
dgarozzo offline
Re: Automatic OBD-II Indigo Plugin
I’ve never had a problem with it.
Fri Aug 31, 2018 8:59 am
I drive my car about once every couple of weeks (sometimes 3+ weeks) - I've not noticed any symptoms of battery drain. My guess is that it doesn't try to talk to the 3G network except when there are explicit events (start, stop, etc). Probably doesn't use much of any power when the car is off - it just needs enough to see when the signal comes that the car started.
Fri Aug 31, 2018 9:11 am
Asking as I had a problem with an insurance plugin - less $ for save driving and we have a car that is rarely used.
That was draining the battery
Sat Sep 01, 2018 7:11 am
roussell offline
I haven’t seen any problems either, and one of my vehicles is rarely driven.
Terry
