Re: Somfy/RTS control
Posted: Wed Aug 01, 2018 4:15 pm
OK, looking over the data, you definitely have some bogus known devices data, and I don't think the instructions in my last post will clean them up.
So, edit the preferences file for the plugin, which is at <Indigo install>/Preferences/Plugins/com.flyingdiver.indigoplugin.rfplayer.indiPref
First, delete all the Indigo devices for the shades, then disable the plugin. Use a plain text editor to edit the file.
Delete everything between these two lines:
Save the file, then restart the plugin. You'll need to use your remote again so that the RFPlayer sees the commands and adds them to the known devices list. Then recreate the Indigo devices.
Sorry for all this. I'm going to work on code to try to clean this up automatically, but that's going to take a bit of work.
- Code: Select all
<knownDevices type="dict">
</knownDevices>
