Page 2 of 5
Re: Pre-release version 7.1.0
PostPosted: Sun Jul 29, 2018 7:42 am
by koburg
FlyingDiver wrote:
Somehow I totally missed that post from March with the Somfy device info. Can you capture that again and this time post it here with CODE tags. The other post is missing most of the JSON punctuation, which makes it harder to decipher. Or zip up the log and post it to a new GitHub issue: https://github.com/FlyingDiver/Indigo-RFPlayer/issues
here it is
29. jul. 2018 15.40.26
   RFPlayer                        Known device list:
knownDevices : (dict)
     RTS-3191872 : (dict)
          description : Shutter (string)
          devices : (list)
               Item : 1741008089 (integer)
          frameData : (dict)
               header : (dict)
                    cluster : 0 (string)
                    dataFlag : 0 (string)
                    floorNoise : -82 (string)
                    frameType : 0 (string)
                    frequency : 433420 (string)
                    infoType : 3 (string)
                    protocol : 9 (string)
                    protocolMeaning : RTS (string)
                    rfLevel : -27 (string)
                    rfQuality : 10 (string)
               infos : (dict)
                    qualifier : 7 (string)
                    qualifierMeaning : (dict)
                         flags : (list)
                              Item : Up/On (string)
                    subType : 0 (string)
                    subTypeMeaning : Shutter (string)
          playerId : 1124932660 (integer)
          status : Active (string)
     RTS-3322944 : (dict)
          devices : (list)
               Item : 322467678 (integer)
          frameData : (dict)
               header : (dict)
                    floorNoise : -93 (string)
                    frequency : 433920 (string)
                    rfLevel : -66 (string)
                    rfQuality : 6 (string)
               infos : (dict)
                         flags : (list)
     RTS-3388480 : (dict)
          devices : (list)
               Item : 513280744 (integer)
          frameData : (dict)
               header : (dict)
                    floorNoise : -87 (string)
                    rfLevel : -35 (string)
               infos : (dict)
                         flags : (list)
          playerId : 1580545739 (integer)
     X10-A1 : (dict)
          description : X10-A1 (string)
          devices : (list)
               Item : 1428924100 (integer)
          infoType : 0 (string)
          protocol : 1 (string)
          protocolMeaning : X10 (string)
          subType : None (string)
     X10-A2 : (dict)
          description : X10-A2 (string)
          devices : (list)
               Item : 839629549 (integer)
is this better ?
PostPosted: Sun Jul 29, 2018 7:43 am
by FlyingDiver
koburg wrote:
is this better ?
Yes.
Re: Somfy/RTS control
PostPosted: Sun Jul 29, 2018 7:45 am
by FlyingDiver
Now can you turn on debug level logging and use your remove to open and close (or close then open) just one of the shutters. The commands for those should show up in the log.
PostPosted: Sun Jul 29, 2018 7:55 am
by koburg
norcoscia wrote:
koburg wrote:
norcoscia wrote:
What type of rollers do you have - if somfy there is a plug in or you can control with a script if you have their bridge.
It is Somfy what plugin. I have rfplayer plugin.
The PlugIn is called Somfy Manager (it is in beta but works great). It was written by user howartp. It will require the Somfy Mylink bridge to work. The bridge handles the translation from IP to Somfy RF. If you want any more info just let me know... happy to help.
Ok thanks but.
Im from Europe and the device they have similar to this from Somfy is called Connexoon io
https://shop.somfy.dk/styringer/connexoon
and I could buy mylink but pay around 200 $ for this I can just buy the rfxcom device for around 80$ and control many other devices.
the reason I bought this rfplayer was the two radios and that they stated on the website that it was so easy to use but that is not the truth as
I Worte earlier I spent more than 20 hours just try making the Somfy work with parrot and no support from the rfplayer company.
PostPosted: Sun Jul 29, 2018 8:02 am
by koburg
Yes I have tried with the verbose logging on but only this is showing
RFPlayer Threaddebug            RF Dongle: Frame from RTS-3322944, known and not configured.  Ignoring.
PostPosted: Sun Jul 29, 2018 8:09 am
by koburg
i have found a guide here from the French controller called JEEDOM
someone made a guide how the rfplayer is setup they are using the parring mode ASSOC please see the guide use google translate it is on French I believe.
https://blog.domadoo.fr/guides/motorisations-somfy-rts-dispositifs-rfplayer-jeedom/
there are another controller called eedomus which also use same method
https://doc.eedomus.com/en/index.php/Eedomus_and_RFPlayer. (English)
PostPosted: Sun Jul 29, 2018 8:13 am
by koburg
this is json code taken from the rfplayer software
ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-62", "floorNoise": "-89", "rfQuality": "6", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "3322944", "qualifier": "7", "qualifierMeaning": { "flags": ["Up/On"]}}}}
ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-61", "floorNoise": "-88", "rfQuality": "6", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "3322944", "qualifier": "1", "qualifierMeaning": { "flags": ["Down/Off"]}}}}
ZIA33{ "frame" :{"header": {"frameType": "0", "cluster": "0", "dataFlag": "0", "rfLevel": "-53", "floorNoise": "-86", "rfQuality": "8", "protocol": "9", "protocolMeaning": "RTS", "infoType": "3", "frequency": "433920"},"infos": {"subType": "0", "subTypeMeaning": "Shutter", "id": "3322944", "qualifier": "4", "qualifierMeaning": { "flags": ["My"]}}}}
PostPosted: Sun Jul 29, 2018 8:17 am
by FlyingDiver
First, update to the latest pre-release plugin: https://github.com/FlyingDiver/Indigo-R ... /tag/7.1.1
After you install that and restart, you need to create an Indigo device for each of your shutters. It'll be type RFPlayer -> "Discovered Sensor". Pick one of the RTS devices from that list. (I need to rename that to "Discovered Device".)
Then try using the Indigo client UI to turn that shutter on or off.
PostPosted: Sun Jul 29, 2018 8:20 am
by FlyingDiver
FYI - this message means that the plugin has seen a valid frame to/from this RTS device, but that there's no Indigo device associated with it.
PostPosted: Sun Jul 29, 2018 8:36 am
by koburg
I can add only one of the 3 devices I have but it will not respond
 WebServer                       request to turn off device "test rts" from 127.0.0.1
   RFPlayer Error                  plugin does not define method actionControlSensor
   WebServer                       request to turn on device "test rts" from 127.0.0.1
PostPosted: Sun Jul 29, 2018 8:58 am
by FlyingDiver
Update to https://github.com/FlyingDiver/Indigo-R ... /tag/7.1.2, which should fix that error.
What do you mean "I can add only one of the 3 devices"? What happens when you try to create the others? Are you seeing three devices in the pop-up when you create the device?
PostPosted: Sun Jul 29, 2018 9:00 am
by koburg
no I only See one device to make/add as new indigo device
but the log says known device on all 3 devices (all with different id)
PostPosted: Sun Jul 29, 2018 9:01 am
by FlyingDiver
How many shutters do you actually have?
PostPosted: Sun Jul 29, 2018 9:06 am
by koburg
I have 3 now I can see them
there was some old test rfplayer devices I made some time ago deleted all and made again
now this error in the log
 WebServer                       request to turn off device "rts 3" from 127.0.0.1
   RFPlayer Error                  Error in plugin execution ExecuteAction:
  File "plugin.py", line 314, in actionControlSensor
KeyError: (u'RTS-3388480',)
PostPosted: Sun Jul 29, 2018 9:09 am
by FlyingDiver
Do the "Dump known devices to log" again and post that.
