New plugin - RFPlayer by ZiBlue
Posted: Tue Oct 24, 2017 8:59 am
https://github.com/FlyingDiver/Indigo-R ... v7.0.0.zip
This plugin communicates with the ZiBlue RFPLayer RF multiprotocol USB dongle. The RFPlayer supports transmit and receive commands on the 433MHz and 866MHz bands. This device is similar (I think) to the RFXCOM/RFXTRF device supported by another plugin.
Supported devices include:
See http://rfplayer.com/ for details.
Quick Start
Currently, the plugin has only been tested with Oregon, Visonic, and Domia sensors, and an X10 RF interface unit. Those are all the devices I or my one beta tester had access to. If you get one of these dongles and have other supported devices I will work with you to add support for additional devices.
- Visonic
Domia/ARC
X10
Somfy RTS
Blyss
Oregon Scientific
Quick Start
- Connect the RFPlayer dongle to an available USB port
- Install the RFPlayer plugin
- Optionally set the plugin configuration information for temperature units and plugin update check frequency.
- Create a new RFPlayer device of type "RFPlayer Dongle". Select the serial port the dongle is connected to. Select US or EU depending on your RFPlayer model (different frequency bands are used US vs EU).
- The dongle will start listening for sensor transmissions on the default RF bands. The plugin will collect information about each new sensor that transmissions are received from.
- Create new RFPlayer devices for each sensor. The known devices will be available in the popup list for each device type.
