Indigo 2022.1 and v3.0.29 - some errors in log
Tue May 10, 2022 7:57 pm
srkinard offline
Hey Peter
Just updated Indigo to 2022.1 and mini to macOS 12.3.1
The plugin works, but throws some errors. Before it might have 4 or 5 error lines occasionally, but it seems to hit the same errors in the same spot now when I call the plugin to retrieve the power readings from both my Aeon Labs power strips.
   Z-Wave                          sent "Entertainment Center - All Outlets" raw command [32 01 10]
   Z-Wave Sensor Logger            Requesting power level 1 for node 10
   Z-Wave Sensor Logger            Requesting power level 2 for node 10
   Z-Wave Sensor Logger            Requesting power level 3 for node 10
   Z-Wave Sensor Logger            Requesting power level 4 for node 10
   Z-Wave Sensor Logger            Requesting power level 5 for node 10
   Z-Wave Sensor Logger            Requesting power level 6 for node 10
   Z-Wave Sensor Logger            Requesting power level 7 for node 10
   Z-Wave Sensor Logger            Requesting power level 8 for node 10
   Z-Wave Sensor Logger            Requesting total power levels for node 33
   Z-Wave                          sent "Bedroom Strip - All Outlets" raw command [32 01 10]
   Z-Wave Sensor Logger            Requesting power level 1 for node 33
   Z-Wave Sensor Logger            Requesting power level 2 for node 33
   Z-Wave Sensor Logger            Requesting power level 3 for node 33
   Z-Wave Sensor Logger            Requesting power level 4 for node 33
   Z-Wave Sensor Logger            Requesting power level 5 for node 33
   Z-Wave Sensor Logger            Requesting power level 6 for node 33
   Z-Wave Sensor Logger            Requesting power level 7 for node 33
   Z-Wave Sensor Logger            Requesting power level 8 for node 33
   Z-Wave Sensor Logger Error      Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 164, in zwaveCommandReceived
type: Replacement index 1 out of range for positional args tuple
  File "plugin.py", line 224, in zwaveCommandReceived
Just FYI
Ross
Wed May 11, 2022 12:43 am
Re: Indigo 2022.1 and v3.0.29 - some errors in log
Cool, I’ll look tonight.
It’s been fine in beta!
Wed May 11, 2022 11:15 am
Grab https://github.com/howartp84/ZwaveSenso ... tag/3.0.30 and let me know what happens.
Peter
Wed May 11, 2022 10:11 pm
srkinard offline
Peter
Thanks Peter! All good now!
Ross
Thu May 12, 2022 1:51 am
Thanks, I’ve pushed it to the store.
