Getting value of an Indigo variable with a name in variable
Wed Oct 23, 2019 1:29 pm
mgolden50 offline
I'm stumped! I'm still in the process of converting AppleScripts to Python. These lines worked in AppleScript but are failing when converted to Python. I have to use a variable name rather than an ID because I need to calculate the Indigo variable's name.
Here's the code that fails:
StepNumber = "1" # Temp overide
WateringDayCountVarName = "WateringDaysBetweenCounterLawnZone" + StepNumber # Assign WateringDayCountVarName  to Name of Indigo's Watering Days  Counter variable
WateringDaysBetweenCounterZoneX = indigo.variables["WateringDayCountVarName"].value
indigo.server.log (WateringDaysBetweenCounterZoneX)
Here is the error message:
Script Error Watering Next Step Triggered.py: 'key name WateringDayCountVarName not found in database'
Watering Next Step Triggered.py, line 8, at top level
KeyError: 'key name WateringDayCountVarName not found in database'
Thanks for any help you can provide,
Mike
Wed Oct 23, 2019 2:02 pm
Re: Getting value of an Indigo variable with a name in vari
The problem is that you're asking for a variable named "WateringDayCountVarName", not "WateringDaysBetweenCounterLawnZone1" which I believe is the intent. Remove the quotes in the second to last line. I've make a tweak to make the script a bit more future proof:
# This is the preferred way to manipulate a string
WateringDayCountVarName = "WateringDaysBetweenCounterLawnZone{}".format(StepNumber) # Assign WateringDayCountVarName  to Name of Indigo's Watering Days  Counter variable
# Note the lack of quotes around WateringDayCountVarName - it's a Python variable, not a literal string
WateringDaysBetweenCounterZoneX = indigo.variables[WateringDayCountVarName].value
While using the name of a variable in indigo.variables[] works, it's relatively unsafe as a change to the variable name would break the script. Given how it appears you're using them, though, I suspect that may not be as big an issue for this use-case as it is with other scripts.
Wed Oct 23, 2019 2:21 pm
mgolden50 offline
Jay,
Thanks that worked!
I would've never figured that our on my own.
I tried to post the code as a code block using the code button, but I see the code was not posted as a block. Why?
Wed Oct 23, 2019 2:27 pm
The code was, the error messages were not.
Are you using Tapatalk? It doesn't handle code blocks at all.
Wed Oct 23, 2019 2:34 pm
mgolden50 offline
No, I was using Indigo forum reply form.
But the code didn't show up as a block when I looked at my own post.
Wed Oct 23, 2019 2:36 pm
That's weird. Never seen that behavior.
Wed Oct 23, 2019 3:07 pm
You had BBCode turned off for your post. I enabled it... :D
Wed Oct 23, 2019 3:08 pm
mgolden50 offline
Wed Oct 23, 2019 4:32 pm
mgolden50 offline
How do I concatenate additional text into the string using this format?
[code]
WateringZoneXOn = "Watering Zone {}".format(StepNumber)+" Om"
[/code]
Wed Oct 23, 2019 4:34 pm
WateringZoneXOn = "Watering Zone {}{}".format(StepNumber, " Om")
Or better
WateringZoneXOn = "Watering Zone {} Om".format(StepNumber)
Wed Oct 23, 2019 4:41 pm
mgolden50 offline
Thanks Joe,
Worked great. Still trying to master all of these indirect references to objects.
Wed Oct 23, 2019 5:21 pm
Please enable BBCode on your posts (I only turned it on for the top post). It appears that you have it disabled in your account settings (it's on by default otherwise).
If this is going to be the name of an Indigo variable, which can't contain spaces, I think this is what you want:
WateringZoneXOn = "WateringZone{}Om".format(StepNumber)
