Applescript to python help please
Sun Oct 06, 2019 5:35 pm
bosstdh offline
here is the script guys please help:
tell application "Airfoil"
set rawVolume to volume of speaker "Master Bedroom"
end tell
set value of variable "VolMasterBedroom" to (rawVolume * 100) as integer
end tell
Sun Oct 06, 2019 6:11 pm
Re: Applescript to python help please
end tell
end tell
Use the Airfoil plugin. You shouldn't need a script at all. http://www.indigodomo.com/pluginstore/19/
Sun Oct 06, 2019 6:27 pm
bosstdh offline
hello, what I am trying to do is have the volume on the control page change as the volume is increased or decreased this all worked fine prior to 7.4 version
Sun Oct 06, 2019 6:29 pm
I understand that, but you used AppleScript to do it. Which won't work anymore. So I think using the Airfoil plugin will make this really easy. If you have an Airfoil device defined for the "Master Bedroom" then you can put the volume directly in the control page. Using the plugin is actually easier.
Sun Oct 06, 2019 7:22 pm
bosstdh offline
I know I can use the minus and plus buttons and have them increase/decrease the sound by a value... the reason for the code is to write to a variable that is then visually reflected on the control page by a number of images. hopefully that makes sense
Sun Oct 06, 2019 7:25 pm
I understand. The plugin should give you the current value of the volume of the device. You can trigger on that state, and use the value to set a variable or select the image. It's really the easiest way to get the volume from the Airfoil device.
Sun Oct 06, 2019 7:38 pm
bosstdh offline
ok let me take a look, thank you
