Convert Variable Modification to Python
Wed Oct 02, 2019 7:23 am
Betacruxis offline
Hello,
This is an embedded Applescript I use in several triggers (when some Indigo variables change).
It simply takes variables values, processes, converts and re-writes them.
Would you please be so kind to translate it into Python script?
I'm not familiar with Python, but I intend to get my hands on it soon.
Thanks in advance!
set Hum to round ((value of variable "Suite_Hum") as integer) + 0
if Hum > 100 then
   set value of variable "Suite_Hum" to 100
else
   set value of variable "Suite_Hum" to Hum
end if
set lum to round ((value of variable "Suite_Lum") as integer)
set value of variable "Suite_Lum" to lum
set temp to round ((((value of variable "Suite_Temp") as integer) - 32) * 5 / 9) - 1
set value of variable "Suite_Temp" to temp
Wed Oct 02, 2019 3:52 pm
Re: Convert Variable Modification to Python
First, a note about your script: the first two uses of round don't seem to do anything at all since you are rounding AFTER you convert to an integer. Calling round() on an integer will just return the integer. The first section then adds 0, which again does nothing. So, I'll just skip these parts.
Here's a pretty straight-forward conversion:
suite_hum_var = indigo.variables[ID_OF_Suite_Hum]
hum = suite_hum_var.getValue(int)
if hum > 100:
    indigo.variable.updateValue(suite_hum_var, value="100")
    indigo.variable.updateValue(suite_hum_var, str(hum))
lum = indigo.variables[ID_OF_Suite_Lum]
indigo.variables.updateValue(lum, value=str(lum.getValue(int)))
suite_temp_var = indigo.variables[ID_OF_Suite_Temp]
old_temp = suite_temp_var.getValue(int)
temp = round((old_temp - 32) * 5 / 9) - 1
indigo.variable.updateValue(suite_temp_var, value=str(temp))
I think that's pretty close.
Mon Oct 07, 2019 3:31 pm
Betacruxis offline
Perfect!
Thank you very much.
I'm starting to read and study Python online and is pretty straightforward.
I'm also using your reference page on IndigoDomo.
I thought the change would be difficult, but it isn't.
Yes, I noticed the issue of the rounding after converting... I'm a rookie!
Thanks again.
Tue Nov 26, 2019 7:11 pm
mgolden50 offline
I'm having great difficulty with Python in converting an Indigo variable value to an integer. Here is the code that fails
and the error message. I know that the Indigo variable is a numeric string.
TemperatureOutsideDailyHighPointSun = int(indigo.variables["TemperatureOutsideDailyHighPointSun"].value)
indigo.server.log(TemperatureOutsideDailyHighPointSun)
This is the error I get.
ArgumentError: Python argument types in
ServerInfo.log(int)
did not match C++ signature:
log(CCString message, CCString type='', bool isError=False)
What am I doing wrong?
Tue Nov 26, 2019 7:35 pm
The problem is actually with your second line that tries to log the value. The argument to indigo.server.log() is always a string, but you are passing it an integer. So to get it working cast it to a unicode string (could cast it just to a normal string, but unicode is generally always best):
indigo.server.log(unicode(TemperatureOutsideDailyHighPointSun))
