Convert Sonos Music Selection Apple Script to Python
Fri Aug 23, 2019 1:29 pm
wideglidejrp offline
Following is a simple script I have been using for years with no problems. I would appreciate any suggestions about converting it to Python.
if value of variable "pennwoodDay" is "Sunday" then
   set musicList to {"Sonos Play Tunein - WSHU-FM", "Sonos Play Tunein - KBAQ"}
   set musicToday to some item of musicList
   execute group musicToday
else
   set musicList to {"Sonos Play XM - 50s on 5", "Sonos Play XM - 60s on 6", "Sonos Play XM - 70s on 7", "Sonos Play XM - The Blend", "Sonos Play XM - The Bridge", "Sonos Play XM - The Coffee House", "Sonos Play XM - The Loft"}
   log musicToday
end if
John R Patrick
Author of
Home Attitude
Fri Aug 23, 2019 2:07 pm
Re: Convert Sonos Music Selection Apple Script to Python
This should be pretty close:
import random
# First, create lists of the IDs of each of the action groups you want for Sunday and for
# all other days. Make sure they're numbers, not strings (so no quotes around them).
sunday_list = [IDS_OF_ALL_SUNDAY_ACTION_GROUPS_AS_NUMBERS] # so for instance [123456789, 987654321]
other_days_list = [IDS_OF_ALL_OTHER_ACTION_GROUPS_AS_NUMBERS]
var_value = indigo.variables[INSERT_ID_OF_penwoodDay_HERE].value
if var_value == "Sunday":
    indigo.actionGroup.execute(random.choice(sunday_list))
    indigo.actionGroup.execute(random.choice(other_days_list))
Sat Aug 24, 2019 9:16 am
This worked perfectly. Thanks!
John R Patrick
Author of
Home Attitude
