Script some calculations
Thu May 16, 2019 10:55 am
Betacruxis offline
Hello guys.
I tried to convert to Python the following AS using the syntax in the other translations, but was unsuccessful.
Would you please convert it for me?
Thanks in advance.
set Hum to round ((value of variable "Kitchen_Hum") as integer) + 0
if Hum > 100 then
   set value of variable "Kitchen_Hum" to 100
else
   set value of variable "Kitchen_Hum" to Hum
end if
set lum to round ((value of variable "Kitchen_Lum") as integer)
set value of variable "Kitchen_Lum" to lum
set temp to round ((((value of variable "Kitchen_Temp") as integer) - 32) * 5 / 9)
set value of variable "Kitchen_Temp" to temp
Thu May 16, 2019 1:02 pm
Re: Script some calculations
[MODERATOR NOTE] started a new thread for this post rather than adding it to an existing post.
Untested, but pretty close:
# set Hum to round ((value of variable "Kitchen_Hum") as integer) + 0
kitchen_hum_var = indigo.variables[ID_OF_Kitchen_Hum]
hum = int(round(kitchen_hum_var.value)) # not sure why the +0, doesn't seem to do anything
# if kitchen_hum > 100 then
#    set value of variable "Kitchen_Hum" to 100
# else
#    set value of variable "Kitchen_Hum" to Hum
# end if
if hum > 100:
    indigo.variable.updateValue(kitchen_hum_var, value=str(100))
    indigo.variable.updateValue(kitchen_hum_var, value=str(hum))
# set lum to round ((value of variable "Kitchen_Lum") as integer)
kitchen_lum_var = indigo.variables[ID_OF_Kitchen_Lum]
lum = int(round(kitchen_lum_var.value)) # not sure why the +0, doesn't seem to do anything
#set value of variable "Kitchen_Lum" to lum
indigo.variable.updateValue(kitchen_lum_var, value=str(lum))
# set temp to round ((((value of variable "Kitchen_Temp") as integer) - 32) * 5 / 9)
kitchen_temp_var = indigo.variables[ID_OF_Kitchen_Temp]
temp = (int(kitchen_hum_var.value) - 32) * 5 / 9
# set value of variable "Kitchen_Temp" to temp
indigo.variable.updateValue(kitchen_temp_var, value=str(temp))
I left the old AS code in there so you could see how each line converts. Also, not sure why you have the +0 on the first line, doesn't seem like that does anything so I left it out.
