Enabling/disabling a trigger in Python
Wed May 01, 2019 10:16 am
A user asked how to convert the following AppleScript snippit to Python:
 disable time date action "timer_wakeup”
In order to answer for the benefit of the entire community, I'm posting the reply here. To do this, you want to use the enable() method in the indigo.trigger namespace:
indigo.trigger.enable(IDOFTRIGGER, value=False)
For completeness, passing True will enable the trigger.
Wed May 01, 2019 10:41 am
Herbo offline
Re: Enabling/disabling a trigger in Python
Thanks for the info Jay!
However that doesn't answer my question - your solution is for a trigger.
The original AppleScript was to disable [or enable] a time date action which is typically under the Schedules category. Your solution only addresses Triggers.
AppleScript: disable time date action "timer_wakeup”
-Herb
Wed May 01, 2019 7:47 pm
Hi Herb,
Replace trigger with schedule and it should work:
indigo.schedule.enable(ID_OF_SCHEDULE, value=False)
Wed May 01, 2019 8:01 pm
Herbo offline
Matt-
Excellent - works like a champ!
-Herb
Thu May 02, 2019 8:24 am
FYI, when you change a post you've made earlier, no notification of the change is detected either in the follow function or the RSS feed. So it's likely to go unnoticed. Once you make a post, if you need to add more questions/comments, please post a follow-up. That will trigger all the various notification methods and will likely result in a more timely response.
