copy from URL snapshot to a local file
Sun Dec 02, 2018 11:37 am
johnpolasek offline
In applescript, I used
do shell script "curl -f 'http://192.168.11.xxx:7080/api/2.0/snapshot/camera/yyyyyyyyyyyyyyyy?force=true&apiKey=zzzzzzzzzz -o ~/Documents/DrivewayFolder/Driveway0.jpg"
but in python, neither requests get, put, or post will do it. Do I need to do a get into an indigo variable and then an os call to put into the file?
Tue Dec 04, 2018 11:20 am
Re: copy from URL snapshot to a local file
So, curl is doing 2 things for you here: it's downloading the image data, then it's storing it in the specified file. In Python, this would be two steps: have requests download the data, then write the data to a file:
import requests
url = 'http://192.168.11.xxx:7080/api/2.0/snapshot/camera/yyyyyyyyyyyyyyyy?force=true&apiKey=zzzzzzzzzz'
# Make the request and get the reply
reply = requests.get(url)
# This will raise an exception if the request returned an error
reply.raise_for_status()
# Save the content to a file
with open('/full/path/to/Documents/DrivewayFolder/Driveway0.jpg', 'wb') as image_file:
    image_file.write(reply.content)
Untested but it should be close.
Tue Dec 04, 2018 11:25 am
import os
os.system("/usr/bin/curl -f 'http://192.168.11.xxx:7080/api/2.0/snapshot/camera/yyyyyyyyyyyyyyyy?force=true&apiKey=zzzzzzzzzz -o ~/Documents/DrivewayFolder/Driveway0.jpg")
should do it
if you want to get fancy with the parameters:
import os
apiKey = indigo.variables["variable name where you store the api key"].value
os.system("/usr/bin/curl -f 'http://192.168.11.xxx:7080/api/2.0/snapshot/camera/yyyyyyyyyyyyyyyy?force=true&apiKey='"+apiKey+"' -o ~/Documents/DrivewayFolder/Driveway0.jpg")
and you can do the same for ip number .. camera # ..
{EDIT] Jay's post happened at the same time .. several ways .. mine is for an action, but can also be used in std python
