Bluetooth AS script to Python Help
Sun Oct 28, 2018 4:29 am
Vangelis offline
Hi All,
Need a little help converting the following AS into Python (knowing nothing about Python :) )
AS ....
on run eventArgs
set bluetoothName to [deviceName] of eventArgs
if bluetoothName is "Vangelis" then
execute group "Vangelis Home"
end tell
end if
This AS script takes a feed (bluetoothName) from another program (EventScripts) that listens out for my phone connecting (and disconnecting) from Bluetooth
Any help would be greatly appreciated..
Vangelis
Sun Oct 28, 2018 3:28 pm
Re: Bluetooth AS script to Python Help
Given that the script is executed from somewhere else, it's unlikely a Python conversion is what you need.
Rather, you can either call Indigo's RESTful API from your AppleScript or you can try the script that we posted on Github that allows you execute commands from AppleScript via the Python scripting environment.
Wed Oct 31, 2018 6:35 am
Vangelis offline
Thanks Jay. This put me on the right track with the RestfulApi. Due to Apple Sandboxing I was unable to run the curl command straight from AS (within the application) however I was able to call a Bash script (that contained the curl command) which achieved the objective.
...Vangelis
