network ping applescript to python
Thu Oct 25, 2018 2:02 pm
esprits300 offline
hello, im in the process of converting my AppleScript's to python and this one is giving me issues. below is my attempt at python and below that is the actual working AppleScript. any help is much appreciated! I'm not a programmer so a lot of the syntax is taken from bits and pieces. thanks!
# New Ping
dev = indigo.devices[1619321171] # Your dev ID here
var = indigo.variables[78070398] # Your var ID here
ip = 192.168.0.10
timeout = 20
result = "/sbin/ping -qon -c 1 -W " & theTimeout & " " & theIP & " | /usr/bin/grep % | /usr/bin/sed \"s/.*,\\ //\" | /usr/bin/sed \"s/%.*//\""
If result >0 then
indigo.variable.updateValue(var, value="true")
else
indigo.variable.updateValue(var, value=“false”)
Original APPLESCRIPT:
-- Ping
set theIP to "192.168.0.10" -- The IP of the computer to check.
set theTimeout to 20 -- The time, in milliseconds, to wait before assuming the ping failed.
set theResult to do shell script "/sbin/ping -qon -c 1 -W " & theTimeout & " " & theIP & " | /usr/bin/grep % | /usr/bin/sed \"s/.*,\\ //\" | /usr/bin/sed \"s/%.*//\""
if theResult is "" then
   set theResult to 100
end if
if theResult as number > 0 then
      set value of variable "var_internet_PING" to "false"
   end tell
else
      set value of variable "var_internet_PING" to "true"
   end tell
end if
Thu Oct 25, 2018 3:34 pm
Re: network ping applescript to python
Try this:
import subprocess
ip = "192.168.0.10"
timeout = 20
destination_var_id = 78070398
command = "/sbin/ping -c 1 -W {} {}".format(timeout, ip)
reply = subprocess.call(command, shell=True)
if reply == 0:
    # successful ping
    indigo.variable.updateValue(destination_var_id, value="true")
    # unsuccessful ping
    indigo.variable.updateValue(destination_var_id, value="false")
Thu Oct 25, 2018 7:55 pm
esprits300 offline
works GREAT, thank you! here is my last script to convert. I took the code from above and modified the ping command to use tcpping. if all is okay it outputs open. I wanted to remove the trailing . but it was too much work for me to figure it out. so what I can't figure out is I want the if/else to be if reply == "open." then update the variable. for some reason, I'm guess its looking for integers not characters, I cant get it to evaluate that. you know what I might be doing wrong? the only part im having issues with is on the if. sooo close! thanks again!
#Office Echo
import subprocess
ip = "192.168.0.1"
port = 443
destination_var_id = 11110415
command = "/usr/local/Cellar/tcping/1.3.5/bin/tcping -t 2 {} {} | grep -e open -e timeout | sed 's/192.168.0.* //'".format(port, ip)
if reply == "open":
    # successful ping
    # unsuccessful ping
#END
Fri Oct 26, 2018 5:57 am
use:
reply = subprocess.Popen(command, stdin=subprocess.PIPE, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True).communicate()
reply has 2 components
reply[0] is what you want, standard output
reply[1] contains a potential error message if something goes wrong
use
if reply[0] =="open":
Fri Oct 26, 2018 7:43 am
esprits300 offline
thank you for the response. I do understand the suggestions you mentioned. Im still getting false for every run though. I checked and ran the command manually and got "open." dont know if the . at the end matters (I tried it with and without in the reply). I made all the modifications you suggested but its always false. any ideas?
Fri Oct 26, 2018 7:56 am
Add this to check:
indigo.server.log(unicode(reply))
After reply=
... and which .?
Fri Oct 26, 2018 10:31 am
esprits300 offline
thank you, that helped. I had 2 issues. first the port, ip was reversed and second the eval term should have "open./n" all is working perfect now and im done converting all my applescripts!!! thank you so much! you guys are always so helpful!
Sat Oct 05, 2019 12:39 pm
hamw offline
Hi guys,
Trying to get this to work. Here's what I put together:
Import time
ip = "10.0.1.20”  ##Cameras_Pool_Equipment
timeout = 20
destination_var_id = 711613744
    if reply == 0:
    # successful ping
    # unsuccessful ping
When run in the action group dialog box python editor, it returns an "EOL while scanning string literal" error.
import subprocess
   ip = "10
I opened the script in Xcode and the above is also highlighted in red.
this came back in the log:
Oct 5, 2019, 2:56:49 PM
   Script Error                    Ping Cameras.py: compile() expected string without null bytes
TypeError: compile() expected string without null bytes
Thoughts?
Also, I'd like to string together several pings in one script as below. Do you foresee any trouble with that? I did put in an "import time" so that I could space the pings out.
Import time
import subprocess
timeout = 20
    if reply == 0:
    # successful ping
    # unsuccessful ping
delay 2
ip = "10.0.1.21” #Fam Rm Patio Camera
timeout = 20
destination_var_id = 990844776
if reply == 0:
    # successful ping
    # unsuccessful ping
delay 2
ip = "10.0.1.22”  #Cameras2_Fam_Rm_Walkway
timeout = 20
destination_var_id = 145747591
if reply == 0:
    # successful ping
    # unsuccessful ping
Sat Oct 05, 2019 1:27 pm
First, import should not be capitalized. Fix that.
Second, show the complete script you're using for one ping. The first code you posted is not complete, because it doesn't have the import subprocess line that's giving an error.
Third, watch your indents. The indigo.variable.updateValue call for the if conditional for a success is not indented. And it looks like you might have some other indent errors. Don't mix tabs and spaces. Or use an editor that converts them. I recommend BBEdit for Python programming, if you're not going to use an IDE.
Fourth, no need to use a delay between pings to different devices.
Sat Oct 05, 2019 3:42 pm
hamw offline
Thanks! I got BB edit and found a bunch of editing issues. Fixed those and it seems fine. Appreciate the tip!
Sat Oct 05, 2019 3:44 pm
You're welcome.
