Incrementing a variable and parsing string
Tue Sep 25, 2018 6:33 pm
hamw offline
Was hoping I could get a little help with incrementing a variable +1. i use this for my home audio matrix to change the source. It advances through 4 sources, and then at 4 goes to 0 again, corresponding to "off."
This simple Applescript works:
if value of variable "audio_7_source" = "4" then
      set value of variable "audio_7_source" to "0"
   else
      set value of variable "audio_7_source" to (value of variable "audio_7_source") + 1
   end if
My Python attempt seems to be OK up to the +1 part, but it increments "0" to "01", instead of just going to "1" :roll:
audio_7_sourceVar = indigo.variables[718347542]
if audio_7_sourceVar.value == "4":
   indigo.variable.updateValue(718347542, "0")
   indigo.variable.updateValue (718347542, ((audio_7_sourceVar.value) + ("1")))
On another note, I have a parser I wrote for that switch, and it uses some of the variable actions in this thread... Any easy suggestions as to how to convert this to Python? The issues are the if statement for the variable "vauxResponse", the text item delimiters, picking out the pieces of the serial response from the unit, then stringing the response together. This is the bass/treble set sequence. I moved this post from another thread as it seems this is more appropriate.
using terms from application "IndigoServer"
      if value of variable "vauxResponse" contains "!s" then
         set vauxResponseString to value of variable "vauxResponse"
         if value of variable "vauxLogging_Enabled" is equal to "true" then
            log vauxResponseString
         end if
         set {myTID, AppleScript's text item delimiters} to {AppleScript's text item delimiters, {","}}
         set myList to text items of vauxResponseString
         set AppleScript's text item delimiters to myTID -- It's considered good practice to return the TID's to their original state
         --log list of myList
         --if myList contains less than 5 items then stop
      end if
      try
         if item 2 of myList is "40" then --this is for setting bass and treble.
            set vauxZoneNumber to item 3 of myList
            set vauxBassSetting to item 4 of myList
            set vauxTrebleSetting to item 5 of myList
            log ((vauxZoneNumber as string) & "  " & (vauxBassSetting as string) & "  " & (vauxTrebleSetting as string))
            if vauxZoneNumber is "0" then set value of variable "vauxZoneName" to "Off"
            if vauxZoneNumber is "1" then set value of variable "vauxZoneName" to "Kitchen"
            if vauxZoneNumber is "2" then set value of variable "vauxZoneName" to "FamRm"
            if vauxZoneNumber is "3" then set value of variable "vauxZoneName" to "Study"
            if vauxZoneNumber is "4" then set value of variable "vauxZoneName" to "LivDnRm"
            if vauxZoneNumber is "5" then set value of variable "vauxZoneName" to "GameRm"
            if vauxZoneNumber is "6" then set value of variable "vauxZoneName" to "Patio"
            if vauxZoneNumber is "7" then set value of variable "vauxZoneName" to "Pool"
            if vauxZoneNumber is "8" then set value of variable "vauxZoneName" to "MBR"
            set value of variable "vauxResponseBassTreble" to ((value of variable "vauxZoneName" as string) & "  Bass " & (vauxBassSetting as string) & "  Treble " & (vauxTrebleSetting as string))
            log value of variable "vauxResponseBassTreble" as string
         end if
      end try
This is that response sequence:
   Simple Serial Plugin Debug      Queue has 1 command(s) waiting.
   Simple Serial Plugin Debug      Processing command: *CW,44,1
   Simple Serial Plugin Debug      Sending command:*CW,44,1
   Simple Serial Plugin            Response from serial device (text): !S,40,1,6,8
, of length 13 characters
   Simple Serial Plugin Debug      *CW,44,1
 command completed
   Script                          !S,40,1,6,8
   Script                          1  6  8
   Script                          Kitchen  Bass 6  Treble 8
   Script                          Kitchen(K)  Off   0
   Script                          Kitc Off  0
Thanks very much; just not sure where to get specifics for a situation like this.
Wed Sep 26, 2018 12:13 am
hamw wrote:
indigo.variable.updateValue (718347542, int(audio_7_sourceVar.value) + 1)
Change to what I’ve changed it to.
Variables are string (text) values so you need the integer (numeric) value of it. Also “1” is a string (text) whereas 1 is an integer.
Peter
Wed Sep 26, 2018 1:45 pm
hamw offline
Re: Incrementing a variable
Thanks for the hint... I tried the new line here:
but it threw this error:
[ Script Error                    embedded script: Python argument types in
    VariableCmds.updateValue(VariableCmds, int, int)
did not match C++ signature:
    updateValue(_VariableCmds {lvalue}, boost::python::api::object elem, CCString value)
     embedded script, line 6, at top level
ArgumentError: Python argument types in
Does the initial variable request need to set the number to an integer first? I tried what I think will set to integer and stripped out the quotes, but no joy:
audio_7_sourceVar = int(indigo.variables[718347542].value)
if audio_7_sourceVar == 4:
   indigo.variable.updateValue(718347542, 0)
   indigo.variable.updateValue(718347542, int(audio_7_sourceVar) + 1)
getting this result:
     embedded script, line 4, at top level
Thu Sep 27, 2018 11:52 am
You're very close:
   indigo.variable.updateValue(718347542, str(audio_7_sourceVar + 1))
When you set a variable value, it has to be a string so we do the addition then convert the result to a string (also changed the first update to the string 0).
Thu Sep 27, 2018 12:34 pm
hamw offline
Thank you Jay!
Could I beg for a little help on my parser?
Thu Sep 27, 2018 12:43 pm
Parsing string
         end if
      end if
      try
         end if
      end try
Here's my Pythonic conversion (I've made some assumptions which are listed). I used Pythonic variable names (not camelCase), value unpacking (setting all 5 items in the split string at once), an id to name map via a Python dictionary, etc. This should give you not only how to translate, but also Python features that make things easier than in AppleScript. Untested, but I think it's right.
# Get the entire response string
vaux_response_string = indigo.variables[IDOF_vauxResponse].value
# I'm assuming that the list will always split into 5 items. This avoids setting
# each variable individually. If not, it can be done much like you do it in
# AppleScript by splitting into a list then just grabbing each item.
first_value, second_value, vaux_zone_number, vaux_bass_setting, vaux_treble_setting = vaux_response_string.split(",")
if "!s" in first_value.lower():
    # Get the boolean value of the logging variable and log if it's true
    if indigo.variables[IDOF_vauxLogging_Enabled].getValue(bool):
        indigo.server.log(vaux_response_string)
if second_value == "40":
    # Log the zone and it's settings
    indigo.server.log("{}  {}  {}".format(vaux_zone_number, vaux_bass_setting, vaux_treble_setting))
    # This is a more Pythonic way of doing your zone number map
    zone_map = {
        "0": "Off",
        "1": "Kitchen",
        "2": "FamRm",
        "3": "Study",
        "4": "LivDnRm",
        "5": "GameRm",
        "6": "Patio",
        "7": "Pool",
        "8": "MBR",
    # Save off the current zone name for use later in case it doesn't change for some reason
    vaux_zone_variable = indigo.variables[IDOF_vauxZoneName]
    temp_zone_name = vaux_zone_variable.value
    # If the zone number from the list is in the map's keys, save off the new name and set the Indigo variable
    if vaux_zone_number in zone_map.keys():
        temp_zone_name = zone_map[vaux_zone_number]
        indigo.variable.updateValue(vaux_zone_variable, value=temp_zone_name)
    # Create the string that's going to be set in the variable and logged
    new_string_value = "{}  Bass {}  Treble {}".format(temp_zone_name, vaux_bass_setting, vaux_treble_setting)
    # Set the Indigo variable
    indigo.variable.updateValue(IDOF_vauxResponseBassTreble, value=new_string_value)
    # Log the string
    indigo.server.log(new_string_value)
You'll notice that if you take out all of my explanatory comments, the script is MUCH shorter and more concise than it's AppleScript counterpart.
Thu Sep 27, 2018 3:11 pm
hamw offline
Re: Parsing string
Jay, thank you so much for your effort on this. I am working hard to make these conversions… For me this script would require a ton of digging and trial and error. You have saved me a bunch of time. I will report back in the next few days how it goes.
Ham
Thu Sep 27, 2018 3:56 pm
Re: Parsing string
NP. Given the quantity of scripts you seem to have, you're really going to want to become more self-sufficient, so you might want to do a Python basics/intro tutorial so you're more familiar with basic syntax and concepts (strings vs number literals, etc). It'll help you avoid some of the errors in your first attempt above.
[MODERATOR NOTE] split from original topic and moved to the AppleScript conversion help forum.
Thu Sep 27, 2018 4:12 pm
Re: Parsing string
Note that you could have done pretty much a straight conversion which would have looked very similar to the AppleScript - I chose to use Pythonic features in an effort to help illustrate those.
Fri Sep 28, 2018 3:49 pm
hamw offline
Re: Incrementing a variable and parsing string
This worked fine... much appreciated.
Quick question... your "pythonic conversion" for my parser script looks great and I will try to get to that shortly. Since I'm kind of limited in my approach to programming, is there a straightforward conversion for a line like this, just using the variable names and not worrying about IDs etc?
Finally, you are right, I should try to sit down and do a tutorial of some kind.... but since my day job keeps me busy 60+ hours per week it is a bit tough... My wife expects me to talk to her when I get home... :-) So I appreciate your generous help and will muddle through.
Fri Sep 28, 2018 4:34 pm
You should never use names. If you change the name of the variable (even by accident) the script breaks. Believe me, it's a VERY BAD IDEA. Substituting the ID is simple.
But, if you insist on shooting yourself in the foot:
if indigo.variables["vauxZoneNumber"].value == "0":
    indigo.variable.updateValue("vauxZoneName", value="Off")
Mon Oct 29, 2018 9:00 pm
hamw offline
This is not quite the same situation. I'm trying to set a variable to select an image for a control page based on whether the pool heat is on or the spa heat is on, or neither. Can't figure out how to get this simple translation to work. Here's the applescript that works just fine:
if ((value of variable "Pool_Heat_Pool_Status" is "on") or (value of variable "Pool_Heat_Spa_Status" is "on")) then
   set value of variable "Pool_Heat_Actual_Status" to "true"
   log "Pool/Spa Heat has turned ON"
else
   set value of variable "Pool_Heat_Actual_Status" to "false"
   log "Pool/Spa Heat has turned OFF"
end if
My first attempt:
PoolHeatON = indigo.variables[1920760143]   #Pool_Heat_Pool_Status
SpaHeatOn = indigo.variables[585319771]  #Pool_Heat_Spa_Status
PoolHeatON.value == "on" or SpaHeatOn.value == "on":
  indigo.variable.updateValue(PoolHeatON, "true"
indigo.server.log("Pool/Spa Heat has turned ON")
    indigo.variable.updateValue(SpaHeatOn, "false"
indigo.server.log("Pool/Spa Heat has turned OFF")
Did not work with an error on "else:.".
PoolHeatON.value =="on" or SpaHeatOn.value =="on":
   ((indigo.server.log("Pool/Spa Heat has turned ON") and (indigo.variable.updateValue(PoolHeatON, "true"))
    ((indigo.variable.updateValue(SpaHeatOn, "false") and (indigo.server.log("Pool/Spa Heat has turned OFF"))
Does not work either. Thanks!
Tue Oct 30, 2018 5:47 am
There's a couple of things. First, it looks like your indentation is messed up. Python is very particular about indentation. Second, your first example is missing an 'if'. Thirdly, it looks like you're testing the value of the variable PoolHeatON and--if its value is 'on'--changing its value to 'true'. If neither is true, you're changing the value of SpaHeatOn. Is this what you want to do? In your AppleScript, you're changing the same variable. Here is a modified version which I think matches your AppleScript's logic (obviously untested).
if PoolHeatON.value == "on" or SpaHeatOn.value == "on":
    indigo.variable.updateValue(PoolHeatON, "false")
EDIT: also saw that you were missing some close parentheses.
Tue Oct 30, 2018 9:12 am
Going from his original AppleScript, I believe this is correct:
    indigo.variable.updateValue(123, "true")  # insert ID of Pool_Heat_Actual_Status
    indigo.variable.updateValue(123, "false")  # insert ID of Pool_Heat_Actual_Status
Thu Nov 01, 2018 4:18 pm
hamw offline
Thanks again; that works fine. In my original version I actually tried to set the correct variable, "Pool_Heat_Actual_Status", but then confused myself! :oops:
Appreciate the assistance, Making progress!
