Run multi-line Python script within AppleScript?
Sat Aug 13, 2022 9:31 pm
billearl offline
This has been driving me crazy. I want to run a multi-line Python script within an AppleScript script (no .py file). I'm using Indigo 7.4.
Specifically, I want to to check the onState of a device, then turn that device on or off accordingly, similar to toggle, but conditional on the onState.
If onState is "on", turn the device off, and vice versa. Sounds simple to me, but I can't figure how to do it. I'm a "lite" user of Python.
Can this be done? If so, how?
Sun Aug 14, 2022 7:34 am
Re: Run multi-line Python script within AppleScript?
I have no idea if what you're trying to do is possible, but I recommend you don't even try. Just convert the AppleScript to Python and be done with it. You're going to have to sooner or later, so might as well do it now.
Sun Aug 14, 2022 8:01 am
I saw your post this morning as I was rushing out and thought "nope, i'll let FlyingDiver answer that"...
I completely agree with what he's said, just don't even try.
In terms of python, the following single line will do what you need if you really want it in a single line:
indigo.device.turnOff(796740025) if indigo.devices[796740025].states['onOffState'] else indigo.device.turnOn(796740025)
The syntax is:
some_expression if condition else other_expression
Turn it off if it is on else turn it on
A better multiline approach would be:
myDevID = 796740025
devIsOn = indigo.devices[myDevID].states['onOffState']
if (devIsOn):
   indigo.device.turnOff(myDevID)
   indigo.device.turnOn(myDevID)
Sun Aug 14, 2022 1:34 pm
billearl offline
Thanks very much. I want to use AppleScript for this, run from (Many Tricks) Butler, which does not run Python scripts directly. I just assumed it would be straightforward to encapsulate a multi-line python script in AppleScript, but apparently not. I will try running a separate ".py" file from AppleScript then.
Follow-up:
This works,
do shell script "/usr/local/bin/indigo-host -x '/Users/billearl/Desktop/fan.py'"
where fan.py contains,
myDevID = 100076704
if (devIsOn):
Sun Aug 14, 2022 5:04 pm
billearl offline
Now, I just want to find how to pass the device ID from AppleScript to Python so I can use just one ".py" file to control different devices.
Any ideas?
Sun Aug 14, 2022 5:41 pm
ryanbuckner offline
Any ideas?
Untested by I think you can just do :
do shell script "/usr/local/bin/indigo-host -x '/Users/billearl/Desktop/fan.py ' + dev_id"
then:
# best to test if argv[1] exits and trap or default
import sys
myDevID = sys.argv[1]
if (devIsOn):
Sun Aug 14, 2022 6:48 pm
billearl offline
Thanks. Unfortunately, I can't seem to pass a variable from AppleScript to Python that way.
I tried AppleScript,
set dev_id to 100076704
do shell script "/usr/local/bin/indigo-host -x '/Users/billearl/Desktop/fan.py' " & dev_id
with Python ("fan.py"),
import sys
if (devIsOn):
but the device did not respond.
Another test using,
import sys
print(sys.argv)
seemed to indicate nothing was passed from AppleScript to Python.
Sun Aug 14, 2022 6:51 pm
Try:
do shell script "/usr/local/bin/indigo-host -x '/Users/billearl/Desktop/fan.py " & dev_id & "'"
Need to get the device ID into the single quoted string.
Sun Aug 14, 2022 7:29 pm
billearl offline
That results in an error: (from Script Debugger)
File "/usr/local/bin/indigo-host", line 149, in <module>
main(sys.argv[1:])
File "/usr/local/bin/indigo-host", line 88, in main
args = parser.parse_args()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 1705, in parse_args
args, argv = self.parse_known_args(args, namespace)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 1737, in parse_known_args
namespace, args = self._parse_known_args(args, namespace)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 1943, in _parse_known_args
start_index = consume_optional(start_index)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 1883, in consume_optional
take_action(action, args, option_string)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 1795, in take_action
argument_values = self._get_values(action, argument_strings)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 2235, in _get_values
value = self._get_value(action, arg_string)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/argparse.py", line 2264, in _get_value
result = type_func(arg_string)
File "/usr/local/bin/indigo-host", line 44, in valid_path
raise Exception("The specified path '{}' doesn't exist".format(in_path))
Exception: The specified path '/Users/billearl/Desktop/fan.py 100076704' doesn't exist
Sun Aug 14, 2022 7:48 pm
You've got an errant colon in that line.
Sun Aug 14, 2022 9:05 pm
billearl offline
So it would appear from the error message, "main(sys.argv[1:])", but there are no colons in my code, except for the two colons in the Python if - else conditional. I can't explain why the error message contains what appears to be an extraneous colon.
Mon Aug 15, 2022 6:02 am
Yeah, the problem is actually that the indigo-host script only accepts a valid path for the -x option. No additional arguments allowed.
There's probably some other way to skin this cat, but they're going to be more convoluted.
Mon Aug 15, 2022 10:43 am
billearl offline
How do I get a man page for indigo-host? I'd like to see the options available. Thanks.
Mon Aug 15, 2022 11:28 am
I don't think there's a man page for indigo-host.
Dave@my-mac ~ % man indigo-host
No manual entry for indigo-host
I believe all the helper apps are in usr/local/bin.
Mon Aug 15, 2022 12:15 pm
It’s a Python script. I just read the code.
