Purple Air plugin error
Mon Jan 21, 2019 5:59 pm
Svale_SP offline
Hi there. The Purple Air plugin (0.1.7) is generating the following errors with Indigo 7.2. Any ideas? Thanks
(Latitude/Longitude using correct system values; Using "remote sensors"; range = 5 or 25 miles; dozens of sensors on PA map)
Jan 21, 2019 at 3:44:29 PM
Purple Air Debug Vaidating Plugin Configuration
Purple Air Debug Validation Succesful
Jan 21, 2019 at 3:44:44 PM
Purple Air Debug Building Available Device List
Purple Air Error Error in plugin execution MenuAction:
File "plugin.py", line 187, in buildAvailableDeviceList
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/PurpleAir.indigoPlugin/Contents/Server Plugin/PurpleAir.py", line 110, in GetDevices
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/PurpleAir.indigoPlugin/Contents/Server Plugin/PurpleAir.py", line 154, in parseSensor
KeyError: ('Version',)
Jan 21, 2019 at 3:45:08 PM
Purple Air No devices were discovered within Range - select "Rescan for Sensors" from the plugin's menu to rescan
