Beta Update for PurpleAir Sensors (no device required)
Mon Oct 09, 2017 6:21 pm
mpoulson offline
I have posted an update to the beta of the PurpleAir Sensor plugin. The new version 0.1.4 now support using data from any of PurpleAirs Network of Sensors.
To use the remote sensors you will need to make sure you correctly have your Sunrise/Sunset Longitude and Latitude set. This is used to find the sensors that are closest to you based on a milage range set in the Plugin Configuration.
Install the plugin from https://github.com/mpoulson/Indigo-Purp ... /0.1.5.zip
This plugin supports sensors from http://www.purpleair.com .
Supports measuring the following
-PM1.0
-PM2.5
-PM10.0
-Temperature
-Humidity
-Pressure
-DewPoint
Supports
- PA-II - Outdoor sensor
- PA-I - Indoor sensor
-Any Active sensor from http://www.purpleair.com
Allows you to trigger a fan when the indoor air quality passes into unsafe limits or many other actions!
Please let me know if you have any problems.
Sat Oct 26, 2019 4:26 pm
Svale_SP offline
Re: Beta Update for PurpleAir Sensors (no device required)
Hi. This problem is still around (reported 1/19). Any ideas? Indigo 7.3.1. OS X 10.14.6. Thanks.
Hi there. The Purple Air plugin (0.1.7) is generating the following errors with Indigo 7.2. Any ideas? Thanks
(Latitude/Longitude using correct system values; Using "remote sensors"; range = 5 or 25 miles; dozens of sensors on PA map)
Jan 21, 2019 at 3:44:29 PM
Purple Air Debug Vaidating Plugin Configuration
Purple Air Debug Validation Succesful
Jan 21, 2019 at 3:44:44 PM
Purple Air Debug Building Available Device List
Purple Air Error Error in plugin execution MenuAction:
File "plugin.py", line 187, in buildAvailableDeviceList
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/PurpleAir.indigoPlugin/Contents/Server Plugin/PurpleAir.py", line 110, in GetDevices
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/PurpleAir.indigoPlugin/Contents/Server Plugin/PurpleAir.py", line 154, in parseSensor
KeyError: ('Version',)
Jan 21, 2019 at 3:45:08 PM
Purple Air No devices were discovered within Range - select "Rescan for Sensors" from the plugin's menu to rescan
Sat Oct 26, 2019 5:28 pm
mpoulson offline
I will look at mine tonight to see if I can repro.
Thu Aug 27, 2020 10:23 am
edrabbit offline
Sorry to resurrect an old thread, but I'm also running into this. Any fix available?
Sat Aug 29, 2020 12:45 pm
teejay6 offline
I just installed this plugin, and ran into the same issue. With the bad air quality in California from the fires, this would be valuable information. Thanks!
Sat Sep 05, 2020 12:03 pm
earache offline
Ditto here. We've had lots of bad smoke days and it would be great to tap into this data.
Thu Sep 10, 2020 2:08 pm
Rocco offline
It seems like we've all come looking for the same thing in this fire season, and are all getting the same result :)
Thu Sep 10, 2020 2:12 pm
Rocco offline
I see that this error was reported on the git hub in 2018, with no response, so my guess is that this is an abandoned project.
