I posted this in the Indigo 6 beta forum first, and was redirected here. I just started using the Security Spy plugin after starting to use Indigo 6b. I have never used it with 5.x.
I have Indigo 6 up and running. I also have Security Spy (on another machine, but that is not supposed to matter). All of the following is being done via Indigo 6 client (on yet a third machine).
First Menu/Plugins/Cynical SecuritySpy/Reload results in the following:
- Code: Select all
Reloading plugin "Cynical SecuritySpy 1.1.0b4"
Stopping plugin "Cynical SecuritySpy 1.1.0b4" (pid 1026)
Stopped plugin "Cynical SecuritySpy 1.1.0b4"
Starting plugin "Cynical SecuritySpy 1.1.0b4" (pid 31396)
Started plugin "Cynical SecuritySpy 1.1.0b4"
Next Plugins/Cynical SecuritySpy/Configure...
causes a dialog to appear with a single checkbox. Checking the checkbox and then the default button ("Save", I believe), results in this:
Jan 25, 2013 10:51:35 AM
- Code: Select all
Cynical SecuritySpy Error in getPrefsConfigUiValues:
File ".../Server Plugin/cyin/plug.py", line 250, in getPrefsConfigUiValues
return self._ui._start_ui(init, None, None)
AttributeError: 'NoneType' object has no attribute '_start_ui'
Cynical SecuritySpy Error Error in plugin execution UiGetValues1:
<type 'exceptions.TypeError'>: object of type 'NoneType' has no len()
Cynical SecuritySpy Error in closedPrefsConfigUi:
File ".../Server Plugin/cyin/plug.py", line 260, in closedPrefsConfigUi
self._ui._end_ui(values, cancelled)
File ".../Server Plugin/cyin/configui.py", line 114, in _end_ui
assert self._ui_values is not None
AssertionError
Jan 25, 2013 10:52:24 AM
Cynical SecuritySpy Error Security Spy Server unavailable: (60, 'Operation timed out')
Selecting Plugins/Cynical SecuritySpy/Configure... again, results in this:
- Code: Select all
Error (client) getXmlFromPlugin() caught exception: empty XML string returned
Error (client) runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Cynical SecuritySpy Error in getPrefsConfigUiXml:
File ".../Server Plugin/cyin/plug.py", line 243, in getPrefsConfigUiXml
assert self._ui is None
AssertionError
Double-Clicking the Security Spy Server device results in:
- Code: Select all
Cynical SecuritySpy Error in getIOMConfigUiValues:
File ".../Server Plugin/cyin/plug.py", line 287, in getIOMConfigUiValues
return self._ui._start_ui((props, indigo.Dict()), cls, obj)
File ".../Server Plugin/cyin/configui.py", line 95, in _start_ui
assert self._ui_values is None
AssertionError
Cynical SecuritySpy Error Error in plugin execution UiGetValues2:
