cynical behaviours - garage door not configurable
Posted: Fri Jul 08, 2022 6:17 pm
hi, thanks for addressing the python 3 issues in your very useful plugins,
I'm having trouble with Cynical Behaviours 3.1.0: no sensor devices are available in the dropdown list when attempting to configure a Garage Door. Affects both existing and new doors.
logs as follows:
logs as follows:
- Code: Select all
Cynical Behaviors Error in filter BinarySensorFilter: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 67, in diagnostic_log
yield
File ".../Server Plugin/cyin/plug.py", line 618, in menufilter
menu = filter._evaluate()
File ".../Server Plugin/cyin/filter.py", line 77, in _evaluate
menu = self.evaluate()
File ".../Server Plugin/cyin/filter.py", line 105, in evaluate
return self.sort([item for item in self.generate()])
File ".../Server Plugin/cyin/filter.py", line 109, in sort
return sorted(values, key=lambda s: natural_sort(s[1]))
TypeError: '<' not supported between instances of 'str' and 'int'
