[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed
Thu Aug 13, 2020 2:24 pm
Different Computers offline
Looks like these instructions https://medium.com/@moreless/how-to-fix ... 772d9dd14c would fix this error, but maybe there's another way.
Also, I have no idea how to put that fix into place, because all I'm doing is setting a DRI variable that's a security spy URL.
Made sure I had accepted the SecuritySpy web page self signed cert as valid on the Indigo box, but still getting
http://localhost:8176/variable_url_redirect/redirect?name=CurrentCam load error: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)>
Fri Aug 14, 2020 12:43 am
Re: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify fail
The 2nd and 3rd answers here might be the easier fix to implement:
https://stackoverflow.com/questions/429 ... u/42982144
I’m familiar with the windows version of putting the certs into a .pem with notepad so plugins will be able to use that - not sure how Indigo implement that though?
Tue Aug 25, 2020 5:17 pm
See my instructions here for a potential change to Indigo's Web server that might avoid the error.
