Security Spy - Enable / disable camera
Fri Jun 05, 2020 4:01 am
raoul offline
Could anyone tell me if it is possible to (remotely) enable / disable a camera within security spy?
I only want this camera activated at certain times due to it's location. While I can physically enable and disable the camera, when done this way I get error messages from Security Spy that it can't connect to the camera. As such I figure the best option might be to disable the camera within the setup controls when not needed and enable when needed.
Would it be possible to do this with a python script and if so would anyone have an example?
Many thanks.
Fri Jun 05, 2020 7:21 am
Korey offline
Re: Security Spy - Enable / disable camera
Use the "Arm Camera" command:
Screen Shot 2020-06-05 at 6.20.55 AM.png (361.21 KiB) Viewed 2820 times
Korey
Fri Jun 05, 2020 7:51 am
raoul offline
Re: Security Spy - Enable / diable camera
Thank you for the suggestion. However I'm actually looking to enable the camera within Security Spy rather than use Motion, Action or any of the recording settings. I enclose a screenshot below with the setting highlighted in red to demonstrate.
Thanks.
Screenshot 2020-06-05 at 14.46.23.png (164.84 KiB) Viewed 2811 times
Fri Jun 05, 2020 8:40 am
Korey offline
Fire an external apple script:
Disable:
property thePath : "http://user:pass@127.0.0.1:8000/++camerasetup"
-- Disable camera 2:
do shell script "curl -d " & "'cameraNum=2&camEnabledCheck=0&action=save' " & thePath
enable:
property thePath : "http://pass:user@127.0.0.1:8000/++camerasetup"
-- Enable camera 2:
do shell script "curl -d " & "'cameraNum=2&camEnabledCheck=1&action=save' " & thePath
Korey
Sun Jun 07, 2020 1:36 pm
raoul offline
Thanks so much. That worked a treat.
