[SOLVED] Error power toggling my TV using 1.8 and 1.9
Thu Apr 09, 2020 12:55 pm
Stoutjesdijk offline
Hi there,
I used iLearn to obtain an IR code to power toggle my TV. Using iLearn, this code works. When I put it into Indigo and use the CynicalCache plugin (either version 1.8.0 or 1.9.0) I get an error like the one below. I am using the IP2IR to send the signal. As you can see, I just reloaded the plugin. What could be causing this error?
Many thanks,
Mark
   Cynical Caché                   plugin starting asyn operation
   Reloading plugin "Cynical Caché 1.8.0"
   Stopping plugin "Cynical Caché 1.8.0" (pid 58304)
   Cynical Caché                   shutdown sensed
   Cynical Caché                   AppleTV stopping
   Cynical Caché                   Global Cache GC100 stopping
   Cynical Caché                   Global Cache iTach IP2ir stopping
   Cynical Caché                   IR Blaster stopping
   Stopped plugin "Cynical Caché 1.8.0"
   Starting plugin "Cynical Caché 1.8.0" (pid 58399)
   Cynical Caché                   API version 2.3
   Cynical Caché                   Python version 2.7.10.final.0
   Started plugin "Cynical Caché 1.8.0"
   Cynical Caché                   mapping device "AppleTV" 4299310(iremitter)
   Cynical Caché                   AppleTV starting
   Cynical Caché                   mapping device "Global Cache iTach IP2ir" 1994741579(gcnet)
   Cynical Caché                   Global Cache iTach IP2ir starting
   Cynical Caché                   Global Cache iTach IP2ir connecting to host
   Cynical Caché                   mapping device "Global Cache GC100" 806735097(gcnet)
   Cynical Caché                   Global Cache GC100 starting
   Cynical Caché                   Global Cache GC100 connecting to host
   Cynical Caché                   mapping device "IR Blaster" 509211027(iremitter)
   Cynical Caché                   IR Blaster starting
   Cynical Caché                   using no IR database
   Cynical Caché                   Global Cache iTach IP2ir is now exploring
   Cynical Caché                   Global Cache iTach IP2ir enabling idle probes
   Cynical Caché                   Global Cache GC100 is now exploring
   Cynical Caché                   Global Cache GC100 ready with 4 device(s)
   Cynical Caché                   Global Cache GC100 version 2.4-06
   Cynical Caché                   Global Cache iTach IP2ir ready with 3 device(s)
   Cynical Caché                   AppleTV host device Global Cache iTach IP2ir now available
   Cynical Caché                   AppleTV is now ready
   Cynical Caché                   IR Blaster host device Global Cache iTach IP2ir now available
   Cynical Caché                   IR Blaster is now ready
   Cynical Caché                   Global Cache iTach IP2ir version 710-1005-05
   Action Group                    Toggle TV Power
   Cynical Caché                   send <Symbol/generic:37000 [(10,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (10,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725), (10,48), (16,16), (16,48), (16,2725)]...[(128,64), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,16), (16,48), (16,16), (16,48), (16,48), (16,48), (16,48), (16,16), (16,48), (16,2725)]> to <IOM+ 509211027=IR Blaster> repeating 0
   Cynical Caché Error             in runConcurrentThread: Traceback (most recent call last):
  File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
    yield
  File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
    return method(*args, **kwargs)
  File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
    self.run()
  File ".../Server Plugin/asyn/inject.py", line 61, in run
    asyn.Controller.run(self)
  File ".../Server Plugin/asyn/controller.py", line 105, in run
    item._can_read()
  File ".../Server Plugin/asyn/selectable.py", line 231, in _can_read
    self._scan(input)
  File ".../Server Plugin/asyn/scan.py", line 65, in _scan
    result = self.scan.scan(self._rbuf, self.callout)
  File ".../Server Plugin/asyn/scan.py", line 123, in scan
    callout(ctx, *m.groups())
  File ".../Server Plugin/asyn/core.py", line 152, in callout
    results = [cb(ctx, *args) for cb in list(self._callbacks)]   # latch callback list
  File ".../Server Plugin/ir/gcache/gcnet.py", line 211, in _calldown
    self.callout_error(Error(code, self._errors[code]))
KeyError: 28
   Cynical Caché Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Best regards,
Mark
Trying to tie it all together...
| Indigo | Plex | NAD M33 | Unifi | LG WebOS | Tado | Sonos | SolarEdge | HUE |
Thu Apr 09, 2020 2:06 pm
Re: Error power toggling my TV using 1.8 and 1.9
Turned out to be something wrong in the Code. I went to the GlobalCache Control Tower, downloaded better codes and everything works fine again!
Best regards,
Mark
