SecuritySpy setting up a server device
Wed Jul 31, 2019 6:26 pm
towsled offline
With the release of SecuritySpy V5 I thought I would use this plugin to integrate my video system into several Indigo events. I went to setup up the server device and for some crazy reason I can not make it work. Indigo and SecuritySpy are running on the same Mac Mini so I left host blank. My Security web server is setup and confirmed that it works. I am using https on port 8001 so I have indicated 8001 as the port. I have a web user that is setup and I confirmed that it works through the SecuritySpy app. When I try and setup the server I get the following error:
Cynical SecuritySpy Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 66, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 76, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 61, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 105, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 231, in _can_read
self._scan(input)
File ".../Server Plugin/asyn/scan.py", line 65, in _scan
result = self.scan.scan(self._rbuf, self.callout)
File ".../Server Plugin/asyn/scan.py", line 123, in scan
callout(ctx, *m.groups())
File ".../Server Plugin/asyn/core.py", line 152, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/http.py", line 280, in _headers
self.callout('headers', self.h_reply)
File ".../Server Plugin/spy/core.py", line 139, in reply
server = arg["Server"]
KeyError: 'Server'
Cynical SecuritySpy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Cynical SecuritySpy Error new device unavailable: ('301', 'Moved Permanently')
Any thoughts on what I am doing wrong?
Dan..
Mon Oct 14, 2019 9:42 am
thumpinc offline
Re: SecuritySpy setting up a server device
Having the same issue. Any help at all out there?
Mon Oct 14, 2019 12:13 pm
Umtauscher offline
As far as I know you have to use the http port which is 8000 by default.
Cheers
Wilhelm
