Camera Size Error
Sat Jul 20, 2019 4:51 pm
roquej offline
Camera Size Error
Since upgrading to plugin version 2.40 and SecurigySpy 5.0.1, I am getting the error:
Cynical SecuritySpy Error <IOM+ 200791151=Camera> ZERO CAMERA SIZE SETUP
Any suggestions?
JP
Sat Jul 20, 2019 5:35 pm
aldera offline
Re: Camera Size Error
I'm getting the same error with the same versions of the software.
<IOM+ 1690721554=Camera_Garage_Basement> ZERO CAMERA SIZE SETUP
Tue Jul 23, 2019 6:29 pm
kwijibo007 offline
+1 but only on one of my 4 cameras which is a Doorbird 720p camera.
Great plugin by the way. Thanks for the quick turnaround in supporting v5.
Thu Jul 25, 2019 9:33 am
jalves offline
Also having the same error. I've got 8 cameras but the error only occurs on one of them. Security Spy 5.0.1, plug-in 2.4.0
Jeff
Thu Jul 25, 2019 9:36 am
jalves offline
Just to add another data point, I just went to another of my cameras and changed the Input stream number from 2 to 1 for that camera. As so as I did that, I got the error message for that camera as well.
Jeff
Mon Jul 29, 2019 10:57 pm
Perry The Cynic offline
You can ignore this message unless you actually want to use the image size (height/width) state of a Camera device. I put that debug message into my plugin to debug a case where SecuritySpy seems to be reporting zero or missing size information, and the logging code escaped into the release.
This message does not indicate that anything is going wrong (other than the image size calculation).
Cheers
-- perry
Sat Aug 03, 2019 10:08 am
The latest version of Cynical SecuritySpy has that error message removed. Sorry for the confusion.
Cheers
-- perry
Mon Aug 05, 2019 10:54 am
aldera offline
Cheers
-- perry
Hi Perry,
I'm running v2.4.2 of your software along with SecuritySpy 5.0.1 and Indigo 7.3.1 and still getting the error.
Aug 5, 2019 at 12:46:18 PM
Z-Wave received "Module_Indoor_ Dehumidifier" power load to 51.024 W
Z-Wave received "Module_Indoor_ Dehumidifier" power load to 64.906 W
Z-Wave received "Module_Indoor_ Dehumidifier" power load to 304.805 W
Cynical SecuritySpy Error <IOM+ 503015034=Camera_Backyard> ZERO CAMERA SIZE SETUP
Cynical SecuritySpy Error <IOM+ 1737082540=Camera_Garage_Main> ZERO CAMERA SIZE SETUP
Cynical SecuritySpy Error <IOM+ 571790624=Camera_Loft> ZERO CAMERA SIZE SETUP
Mon Aug 05, 2019 11:12 am
norcoscia offline
I just got two of them today and I’m on the newest build. They appeared after a camera schedule action ran. I opened and reselected the items and resaved the schedule. Manually ran w/o error, I’ll Let you know if I see them again....
P.S. Even with the error the schedule action ran properly.....
_______
Norm
Tue Aug 06, 2019 9:03 pm
Nah, I managed to not include that cleanup in the 2.4.2 release. Blame my scatterbrain.
2.4.3. Thanks for keeping me honest. :-)
Cheers
-- perry
