Error in Plugin - 7.3.1
Tue May 28, 2019 8:05 pm
Dlucas10 offline
Hello!
I upgraded to 7.3.1 and now I'm receiving continuous error in the log. Is the plugin still being monitored and developed on?
Cynical Denon Error             in runConcurrentThread: Traceback (most recent call last):
  File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
    yield
  File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
    return method(*args, **kwargs)
  File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
    self.run()
  File ".../Server Plugin/asyn/inject.py", line 61, in run
    asyn.Controller.run(self)
  File ".../Server Plugin/asyn/controller.py", line 98, in run
    timeout = max(0, self._schedq[0].when - time.time()) if self._schedq else None
TypeError: unsupported operand type(s) for -: 'NoneType' and 'float'
   Cynical Denon Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
    yield
    self.run()
    yield
    self.run()
    yield
    self.run()
    yield
    self.run()
Sat Jun 01, 2019 11:01 am
Re: Error in Plugin - 7.3.1
I haven't used this plugin but have you tried restarting the plugin? If that doesn't work what about a restart of the Indigo Server?
If all that fails, then you might try recreating your Indigo devices/actions/triggers for this plugin.
