Weather not returning temp units
Mon Nov 05, 2018 8:29 am
abplus offline
Hi all,
Can you help please ?
I can't find a way to display the temperature unit °C after the temp data in my control page. What am I doing wrong please ?
Andrew.
Mon Nov 05, 2018 9:29 am
Re: Weather not returning temp units
You can create another Control Page element that is just static text for the °C and place it directly to the right of the device state control.
Fri Nov 09, 2018 7:56 am
abplus offline
Hi Matt, thanks for the reply. That's what I'm doing at the moment. Unfortunately I'm also using temp data from a Fibaro door sensor that returns the temp with the unit in the string. I can't line the text up in my control page, see attached.
Kindest regards,
Andrew.
Screenshot 2018-11-09 at 13.54.58.png (64.63 KiB) Viewed 2426 times
Fri Nov 09, 2018 10:13 am
Can't you use the raw state value rather than the UI value of the door sensor? It should have just the raw value (the number only) as a state.
Fri Nov 09, 2018 4:07 pm
abplus offline
Thanks Jay.
Unfortunately the Fibaro sensor has no parameter setting to return raw data unless there is another way to get it that I don't know.
Fri Nov 09, 2018 6:02 pm
Select the Plugins->Open Scripting Shell menu item. In the resulting Python script window, paste in (after substituting the ID for your Fibaro sensor):
print(unicode(indigo.devices[ID_OF_FIBARO]))
Copy/paste the results of that command into a reply.
Sun Nov 11, 2018 1:55 pm
abplus offline
Thanks Jay, here it is:
address : 27
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwValueSensorType
displayStateId : sensorValue
displayStateImageSel : TemperatureSensor
displayStateValRaw : 17.1
displayStateValUi : 17.1 °C
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          SensorUnits : 1 (integer)
          SupportsOnState : false (bool)
          SupportsSensorValue : true (bool)
          address : 27 (integer)
          disableStatusLogging : false (bool)
          indigoObjVersion : 8 (integer)
          modelNameAndFirmware : Door/Window Sensor 2 (FGDW002), firmware 3.02 (string)
          propsPushTickler : 1 (string)
          tempAlwaysFalse : false (bool)
          userPollInterval :  (string)
          userPollingEnabled : false (bool)
          userWakeInterval :  (string)
          version : 3.02 (string)
          zwAssociationsMapStr :  (string)
          zwClassCmdBase : 0 (integer)
          zwDevSubIndex : 2 (integer)
          zwEncryptionStatusStr :  (string)
          zwManufactureId : 271 (integer)
          zwManufactureName : Fibaro System (string)
          zwModelId : 117575680 (integer)
          zwModelName : Door/Window Sensor 2 (FGDW002) (string)
          zwNodeNeighborsStr :  (string)
          zwShowDumpDevToLog : false (bool)
          zwShowMainUI : false (bool)
          zwShowManualModifyConfigParmUI : false (bool)
          zwShowPollingUI : false (bool)
          zwShowSubmitModelInfoUI : false (bool)
          zwShowWakeIntervalUI : false (bool)
lastChanged : 2018-11-11 19:28:27
lastSuccessfulComm : 2018-11-11 19:28:27
model : Door/Window Sensor 2 (FGDW002)
name : Boot Room Temp
onState : None
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
sensorValue : 17.1
states : States : (dict)
     sensorValue : 17.100000 (real)
     sensorValue.ui : 17.1 °C (string)
subModel : Temperature
supportsAllOff : False
supportsOnState : False
supportsSensorValue : True
supportsStatusRequest : True
version : 3.02
Mon Nov 12, 2018 4:42 pm
I think you are going to need to create a virtual device using the very handy Adapters Plugin to handle this case. Using that you can customize exactly how you want the value formatted.
Tue Nov 13, 2018 3:01 pm
abplus offline
Thanks very much Matt, I'll give it a go.
A.
