Cynical Weather Error
Posted: Wed Jun 06, 2018 10:38 am
I have been getting a regular stream of errors for this plugin. I updated the plugin via the store, restarted indigo and rebooted. The error seems to persist. Has anyone else seen this issue?
Cynical Weather Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Cynical Weather Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 61, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 105, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 229, in _can_read
self._null_read()
File ".../Server Plugin/asyn/selectable.py", line 97, in _null_read
self.callout(END)
File ".../Server Plugin/asyn/core.py", line 152, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/ssl.py", line 140, in incoming
super(SSL, self).incoming(ctx, data)
File ".../Server Plugin/asyn/selectable.py", line 387, in incoming
return self.callout(ctx)
File ".../Server Plugin/asyn/http_chunk.py", line 44, in incoming
return super(ChunkedCoder, self).incoming(ctx, data)
File ".../Server Plugin/asyn/zfilter.py", line 44, in incoming
self.callout(ctx)
File ".../Server Plugin/asyn/http.py", line 304, in incoming
return self.callout('body', self.body)
File ".../Server Plugin/forecast/core.py", line 193, in cb
callout(asyn.Context('reading'), Reading(args[0]))
File ".../Server Plugin/forecast/core.py", line 128, in __init__
s = json.loads(data)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/__init__.py", line 338, in loads
return _default_decoder.decode(s)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 384, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
