Itach Flex Wifi - Serial
Posted: Tue Jan 09, 2018 6:23 am
I'm brand new to Indigo (day 2), and Mac! I've previously been using Fibaro HC2.
I have a Global Cache iTach flex wifi, with a serial connection which I use to control some equipment - this works fine in the Fibaro HC2.
In Indigo, I have downloaded and installed the cynic plugin, I have then created a device, or Type Cynical Cache, Model = Network device and inserted the iTach's ip address (xxx.xxx.x.xxx) with no port.
When I then try to create a second device, I am unable to connect / get working, using any of the models to choose from. Also, I do not get any log file created.
I have tried to install the other Global Cache plugin, and successfully setup the network device, but again I could not get a serial cable to work... I did however at least get a log file created.
Can anyone help - does the cynical plugin work with serial (Rs485 / RS232), and if so, how do you set it up?
Many thanks,
Many thanks,
