Cynical Security spy. Cameras changes status at midnight
Sun Jan 07, 2018 3:10 am
mortenkols offline
Hello.
I have recently noticed a problem with security spy. Every evening at midnight (00:00) all my cameras changes status from active to passive. I dont know if its because of Indigo plugin or Security spy mac app.
It dosent change the continuous capture state, only motion state.
I have no schedule at midnight that should change state on my cameras.
I haven't set up schedule in the Security spy mac app.
Any suggestion on why this is happening?
Skjermbilde 2018-01-04 kl. 23.57.16.png (22.1 KiB) Viewed 3396 times
Skjermbilde 2018-01-04 kl. 23.58.59.png (49.2 KiB) Viewed 3396 times
Skjermbilde 2018-01-05 kl. 00.00.21.png (20.44 KiB) Viewed 3396 times
Skjermbilde 2018-01-05 kl. 00.00.31.png (44.11 KiB) Viewed 3396 times
Sun Jan 07, 2018 3:56 am
Lucardos offline
Re: Cynical Security spy. Cameras changes status at midnight
Your not only in this. I noticed it to, but for me only 4 camera's (out of 8 ) are put into non-active every night at 0:00..
I thought it was only me and put a schedule to put all camera's back into active at 10 seconds after midnight. but have not checked the real reason why this happens.
Lucas
Sun Jan 07, 2018 8:48 am
jh71283 offline
Why not disable the cynical plugin to rule it out?
Sun Jan 07, 2018 8:52 am
Colorado4Wheeler offline
Agreed, that would make sense as a diagnostic measure.
That being said, I use the plugin extensively and don't have that problem. Most of my "active" enabling is controlled by SS anyway as I use motion detection over constant recording.
Wed Jan 10, 2018 2:16 am
mortenkols offline
Last night I did disable the cynical security spy plugin in indigo. All the cameras changing state at midnight. So, its not indigo who is causing the problem.
Wed Jan 10, 2018 9:04 am
One thing you could try is to use multiple recording files instead of a single recording for the day, perhaps the switch from one day to the next is causing the recording to stop. Have you tried using a schedule instead of 24/7 recording? It can still be 24/7 but, then again, maybe something in 24/7 (or in a schedule if that is how you are set up already) is the issue.
Wed Jan 10, 2018 11:55 pm
mortenkols offline
I havent set up schedule in security cam mac app. Everything is controlled by indigo. Its only recording when im sleeping and when im not home
