I've setup Cynical Network with my new GlobalCache GC-100 and it's sending IR and Serial fine.
What it isn't doing is receiving (or processing) any incoming response.
I've used Putty on my Windows PC to connect to the GC100 and send the commands manually, and each receives an acknowledgment. Sending a status request receives the requested data.
My TCP_Out device is set to log responses to a variable, and I've also set an Unrecognised Input trigger to toggle my study fan, but nothing is happening - no data in the variable or toggled fan.
I did notice when testing on Windows that the response doesn't include a line-ending. My LG TV requires CR line endings, which the TCP_Out device is set to append - is this why the plugin is ignoring incoming data, because there's no line-ending? If so, can I send 'CR' manually in each send-text action, then set TCP_Out to 'None'?
Any thoughts/suggestions/ideas?
Peter
