Security Spy Setup and Troubleshooting
Thu Sep 24, 2015 7:53 am
darren1f offline
I've scoured this forum trying to figure out what I'm doing wrong. I'm currently using Security Spy with my IPCC camera. While Security Spy is working with the camera, when I try to integrate with Indigo, it isn't working. I've installed and reinstalled the Security Spy/Indigo plugin, and it continues to hang on "Preparing." As I troubleshoot the various settings, it alternates between "unavailable" and "preparing."
Can someone provide step-by-step instructions. I'm sure I'm missing something obvious.
Has this happened to anyone else that can provide some insight?
Many thanks!
Darren
Fri Sep 25, 2015 11:40 am
Re: Security Spy Setup and Troubleshooting
Just to check you have enabled access within security spy? Also enable the debug log and post it here, that might help!
Mon Sep 28, 2015 7:01 pm
darren1f offline
Thanks for the reply. I believe I've enabled security spy. I really don't know. Here's the event log. Like I said, I wouldn't be surprised if I've overlooked something obvious. I just can't...
Sep 28, 2015, 8:57:04 PM
Reloading plugin "Cynical SecuritySpy 1.6.4"
Stopping plugin "Cynical SecuritySpy 1.6.4" (pid 18850)
Cynical SecuritySpy shutdown sensed
Cynical SecuritySpy Front Camera stopping
Stopped plugin "Cynical SecuritySpy 1.6.4"
Starting plugin "Cynical SecuritySpy 1.6.4" (pid 23590)
Cynical SecuritySpy API version 1.19
Started plugin "Cynical SecuritySpy 1.6.4"
Cynical SecuritySpy mapping device "Front Camera" 113401705(server)
Cynical SecuritySpy Front Camera starting
Cynical SecuritySpy plugin starting asyn operation
Wed Sep 30, 2015 1:18 pm
Interestingly i've just went to re-set up Security Spy after having not used it for a while, and i'm having the same issue.. so I suspect something to do with the latest version. I'm going to try an older version later, i'll report how i get on.
Wed Sep 30, 2015 1:47 pm
Well, this gets stranger and stranger. I've narrowed it down to authentication.. as in if you disable logins then it works fine, but as soon as you enable it i get the exact same as you:
30 Sep 2015 20:40:37
  Cynical SecuritySpy Error       Server - SecuritySpy Server unavailable: ('401', 'Unauthorized')
  Cynical SecuritySpy             Server - SecuritySpy Server stopping
  Cynical SecuritySpy             Server - SecuritySpy Server starting
  Cynical SecuritySpy             Server - SecuritySpy Server reset
  Cynical SecuritySpy             Dining - Camera reset
  Cynical SecuritySpy             Lounge - Camera reset
  Cynical SecuritySpy             Outdoors - Front Door Camera reset
30 Sep 2015 20:42:17
  Cynical SecuritySpy Error       Dining - Camera unavailable: host device Server - SecuritySpy Server is unavailable
  Cynical SecuritySpy Error       Lounge - Camera unavailable: host device Server - SecuritySpy Server is unavailable
  Cynical SecuritySpy Error       Outdoors - Front Door Camera unavailable: host device Server - SecuritySpy Server is unavailable
I've also reverted back to older versions of v2 and v3, i've tried different port numbers for the HTTP setting, i can login using the web interface as i've always been able to, but beyond this as i'm using the exact same plugin as i was previously i can only assume it's something to do with an OSX update. Has anyone else out there had this kind of behaviour?
Wed Sep 30, 2015 4:59 pm
Grognard offline
Running version 1.6.4 of the plugin and 3.4.7 of Security Spy with authentication on a mac mini running 10.9.5, no problems here.
Wed Sep 30, 2015 6:28 pm
darren1f offline
Thanks for looking into this! Very excited to get all this equipment working. I must admit, I was feeling like a bonehead spending all this time and getting nowhere. If you uncover the glitch, please post a step-by-step setup process.
Again, thanks!
Thu Oct 01, 2015 2:06 pm
Alas no joy, I've also tried connecting to a new installation of Security Spy on my MacBook and same issue, so it's got to be either something local to the mac mini or the Indigo plugin. :/
Fri Oct 02, 2015 12:56 pm
darren1f offline
Much appreciate that you've continued to look into this. Do you have any other thoughts regarding any plugins that may work more reliably with Indigo? I've used Blue Iris in the past. But that's not Mac friendly.
Fri Oct 02, 2015 1:03 pm
Well the funny thing is i've had this plugin working fully in the past. And it was rock solid (as Perry's plugins usually are). As best i can tell it's an environmental issue.. but i'm stumped as to what it could be.
Sun Oct 11, 2015 7:55 am
jgli offline
I'm new to Indigo and just purchased the software. I've setup the plug-in but can't figure out how to display the camera on a control page.
Thu Oct 15, 2015 9:43 pm
Take a look at this forum thread. It has the details and an example.
Tue May 07, 2019 10:13 am
martinc offline
I seem to get this error when I run the plugin, any ideas?
May 7, 2019 at 12:12:19 PM
Reloading plugin "Cynical SecuritySpy 2.3.0"
Stopping plugin "Cynical SecuritySpy 2.3.0" (pid 19365)
Stopped plugin "Cynical SecuritySpy 2.3.0"
Starting plugin "Cynical SecuritySpy 2.3.0" (pid 19399)
Cynical SecuritySpy API version 2.1
Cynical SecuritySpy Python version 2.7.10.final.0
Started plugin "Cynical SecuritySpy 2.3.0"
Cynical SecuritySpy Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 64, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 61, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 105, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 231, in _can_read
self._scan(input)
File ".../Server Plugin/asyn/scan.py", line 65, in _scan
result = self.scan.scan(self._rbuf, self.callout)
File ".../Server Plugin/asyn/scan.py", line 123, in scan
callout(ctx, *m.groups())
File ".../Server Plugin/asyn/core.py", line 152, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/http.py", line 280, in _headers
self.callout('headers', self.h_reply)
File ".../Server Plugin/spy/core.py", line 111, in reply
server = arg["Server"]
KeyError: 'Server'
Cynical SecuritySpy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
yield
self.run()
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 229, in _can_read
self._null_read()
File ".../Server Plugin/asyn/selectable.py", line 97, in _null_read
self.callout(END)
File ".../Server Plugin/asyn/http.py", line 304, in incoming
return self.callout('body', self.body)
File ".../Server Plugin/spy/core.py", line 120, in reply
self._configure(arg)
File ".../Server Plugin/spy/core.py", line 155, in _configure
system = ET.fromstring(system_info)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1301, in XML
return parser.close()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1654, in close
self._raiseerror(v)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/xml/etree/ElementTree.py", line 1506, in _raiseerror
raise err
ParseError: no element found: line 1, column 0
