Hello,
I'm using the Cynical Cache plugin which seems to be working on and off. I occasionally get the following issue, but once I reload the plugin it works fine. I'm mostly running it from a trigger.
Pete
Cynical Caché Error in standard_switch: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/irdev.py", line 203, in standard_switch
self.gcdev.engage(active)
File ".../Server Plugin/ir/gcache/gcdev.py", line 242, in engage
self.command("setstate", "1" if active else "0")
File ".../Server Plugin/ir/gcache/gcdev.py", line 70, in command
self.hostdev.command(','.join([cmd, self.address] + map(str, args)))
File ".../Server Plugin/ir/gcache/gcnet.py", line 119, in command
self.hostdev.write(cmd + '\r')
AttributeError: 'NoneType' object has no attribute 'write'
