Not sure if this is the best place to post this but is there a way to transfer a learned IR
code from iRed2 to the Cache IR plugin? Not sure what format iRed uses but it is not hex code.
I have an iTach wifi IR unit but not the learning module so all the codes I've trained
using an IRTrans in iRed, can't be copy and pasted to the plugin.
edit: Any chance an IRTrans might be supported in the future?
Carl
