Cynical Network: Command Fusion iViewer integration.
Sat Oct 04, 2014 1:30 pm
iblis offline
Hello and thank you for this great plugin.
I'm using Cynical Network to integrate my iViewer control screens. It's been a success so far, but I have a couple of questions that would ease my integration a lot.
When I use Send Text from Indigo to iViewer I want to send a string that updates the brightness level on a light.
A typical string looks like this a11=20.
a11 = Analog Joint 11
20 = Brightness level
Instead of creating a string for every brightness level (100) to use in triggers I would like to just use 1 string per device that updates the string with the current state of the device before it sends it.
So something like this (Device 11 = 54), Send Text: a11=device.11.state (that would look like a11=54 on iviewer)
Is this possible?
Best regards,
iblis
Sun Oct 05, 2014 1:53 am
I'm not sure if the plugin is allowed to access device states from other devices, but if it is then I think the following should work:
="a11="+indigo.devices[Dev_ID].brightness
where Dev_ID is the indigo ID of the device you want. (This won't be 11' it will be something like 12586364; right-click on the device in Indigo to find it)
I think .brightness is the correct field for an Indigo dimmer device; if you're using a custom device/plugin, you might need a different field.
This is all guessing based on rough knowledge of Indigi/Python and a quick read of the tutorial, so I may be wrong...!
Peter
