I'm seeing a constant error with the plugin. Whenever I'm trying use one of the presets in SecuritySpy I see the following error in the logs:
- Code: Select all
Cynical SecuritySpy Error in ptz_preset: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
File "plugin.py", line 211, in ptz_preset
command += 100
TypeError: cannot concatenate 'str' and 'int' objects
Is there anything I need to do? Can you offer any advice?
You may have also seen in another thread the screenshot I posted from Cynical Weather where it mislabels one of the drop down menus as Camera.
I've disabled Cynical Weather and restarted both plugins but the same issue with both.
Any advice? Thanks.
